Help... fuel pump issue...
Old Jul 29, 2002 | 09:49 AM
b18c1eg
Guest
Posts: n/a
Default Help... fuel pump issue...
I have a 92 Civic DX with a 98 GSR swap in it. I also have the GSR fuel pump as well. Every once in awhile, when it's a VERY hot day out (close to 95-100) the fuel pump won't kick on to start the car. I'll click the key to acc. and wait for the pump to kick on and build pressure before I start it... but it never kicks on. Then if I go ahead and try and start it... it'll just die immediately. I'll usually let it sit for about 30 sec. or so, then it's all ok... kicks on and starts up. This only seems to happen on those REALLY hot days... where is the best place to start looking? Is this a typical symptom of a fuel pump going bad? Any help would be greatly appreciated.
Thanks,
Brad
Old Jul 29, 2002 | 10:30 AM
Spade's Avatar
Default Re: Help... fuel pump issue... (b18c1eg)
I would check any wiring that relates to the fuel pump, including voltage of the wiring while on.
Old Jul 29, 2002 | 11:07 AM
b18c1eg
Guest
Posts: n/a
Default Re: Help... fuel pump issue... (Spade)
Do you happen to know what the voltage should be? Thanks for the response.
AZ accord
Sep 10, 2015 03:24 PM
Jooleeus
Dec 22, 2009 06:47 PM
nicko360
15
Jan 17, 2007 06:22 PM
