91 acura integ help, turbo help
Old Oct 20, 2008 | 04:38 PM
cododgeneon's Avatar
Default 91 acura integ help, turbo help
ok so my brother bought a JERRY RIGGED integra. the wires under the hood just twisted together and taped, crap just nasty, oil leaks bad, turbo spits oil, ebay wastegate.
So since we have had it I replaced the turbo, wastegate, fixed oil leaks, installed new wire harness, wired in a 4 bar map sensor.
Questions are it doesnt have a fuel managment on it, no rrfpr or afc. It does have 450cc injectors and a golden eagle fuel rail and edelbrock manifold
Which is better to go with, afc or rrfpr?
Should I replace the 4 bar map with a stock map sensor?
Is a missing link needed with the stock map sensor?
How do you check the CEL codes? I searched 6 pages and couldnt come up with anything
Any help is help
Thanks
Tyson
Old Oct 20, 2008 | 04:42 PM
BoSox46GSr's Avatar
Default Re: 91 acura integ help, turbo help (cododgeneon)
https://honda-tech.com/zerothread?id=978933
Obviously you didn't search hard enough because that's how you jump codes.
Right in the FAQ stickied at the top of the page.
Old Oct 21, 2008 | 07:43 AM
91redteg's Avatar
Default Re: 91 acura integ help, turbo help (BoSox46GSr)
im gonna assume the car isnt obd0 anymore.... just chip whatever ecu it has with crome thats a perfect cheap management keep the 4bar do not replace it with the stock one
Old Oct 23, 2008 | 03:26 PM
Default Re: 91 acura integ help, turbo help (91redteg)
Thanks for the heads up.
New problem. I cant find the green plug under the whole dash. I looked under the passenger side of the dash and I dont see a blue plug that the wires sit in nor do I see a brown/white wire and a black wire paired together to check the codes.
I dont think its been changed under the dash, its all stock looking, just normal wires cut from alarm installs.
Is there another way to check codes? NO obd ports for a code reader.
ed6chuck
Oct 17, 2011 04:55 PM
Carbonciv
Sep 12, 2007 09:02 AM
jdmcivicturbo
Feb 27, 2005 11:18 PM
h22acclude
Oct 23, 2003 02:48 PM
