ground wire ?
Old Oct 20, 2008 | 11:18 AM
turbo-crx's Avatar
Default ground wire ?
i have all the ground wires on all the spots im suppose to, but if i turn on the high beams while the car is on the tach will stop working the temp gauge goes right to H, and the blinker signals light up on the cluster. as soon as i turn high beams off everything goes back to normal. any ideas what it is going on?
Old Oct 20, 2008 | 11:48 AM
IndySporty's Avatar
Default Re: ground wire ? (turbo-crx)
Check the grounds where they go into the cluster istelf, I've seen them broken off at the back before.
Old Oct 21, 2008 | 09:19 AM
turbo-crx's Avatar
Default Re: ground wire ? (IndySporty)
i replaced all the grounds with new thicker grounds and made sure they were connected on the cluster. the battery cables are tight also.....would it have to do with the wiring for the high beams since it only does it when you turn the high beams on?
Old Oct 21, 2008 | 10:16 AM
HaulingAddison's Avatar
I would try checking the bulbs in the gauge cluster. I know if you blow a brake light, it could short the bulb filement out on the tail lights causing your dash and tail lights to come on so maybe something like that might be happening with your dash lights.
sol-oto
Jun 17, 2018 08:56 AM
96Formula6spd
May 19, 2010 03:50 PM
devin_hoang
Nov 21, 2008 10:40 PM
silvergo
May 20, 2005 12:05 PM
fwdftw
Mar 29, 2004 08:04 PM
