is the t3gt40 and a t3t61 the same thing......loking for a cheaper 35r alternative
im looking for cheaper alternatives to something in the 3040 and 35r range or maybe a tad smaller than a 35r but no smaller than a 3076........it has to flow at least enough for 500 whp
anyone know what holset would fit this criteria.........i know there is the holset thread but damn i don't have time to read 100+ pages right now
like in the title im considering a t3gt40 and a t3t61
i had thought about the BW but they are as high or higher than the gt series
anyone know where to buy new holsets?
Modified by spoolin turbo s at 12:30 PM 10/20/2008
dude WTF how many different turbos are you going to ask about in one week ? for real search read compressor maps and learn how to use them effectively. from what i understand Mac has helped you alot.
a BW S256 will hit your needs of 500whp depending on your motor and mods. what motor is this turbo going on ? also a S256 is about $900-$1000 flat
places to buy new holsets
http://www.timsturbos.com/
http://www.htturbo.com/
http://www.dentsport.com/2006/...urbos/
going on a 20V 1.8 VW
he has helped me alot but at that time i was going to be using a a stock head and now im coming into some money and my head will be a lot different
let me put it into honda terms so maybe it makes more sense
imagine you hav an ls you plan to build and your checking around deciding on a turbo based on an ls, then you run accross some money and have a fully built vtec head with all the goodies.........now when you do that don't you think your options on what turbo your going to use is going to change
thats really the best way i can explain it before with the stock head i was thinking 350whp max and now im thinking 550 whp max
where is the cheapest to buy a BW 256
do you know the answer of if a t3gt40 is the same as the t3t61
1k is about the max i want to pay for a turbo
anyone know anything about the precision 6162? i've heard its like a non bb gt35r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s »</TD></TR><TR><TD CLASS="quote">going on a 20V 1.8 VW
thats really the best way i can explain it before with the stock head i was thinking 350whp max and now im thinking 550 whp max</TD></TR></TABLE>
on a vdub get a holset HX40/35 with a 12cm^2 turbine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">
what about a he351cw?
also where does the sc61 fit into this size and price questions
more than likely if i try a holset it will be a used one
how much power is a straight hx35 good for?
</TD></TR></TABLE>what about a he351cw?
a SC61 and holset HX35 are 1st cousins
BUT the holset in my opinion is way more upgradable and has many options.
a HX35 has so many options its hard to give you a ball park because it comes with about 5 different turbine housings. just get what i told you and you will be happy hands down. 12cm^2 turbine is what you need and if you feel you want more power later get a 14cm^2 or 16cm^2 turbine.
BUT the holset in my opinion is way more upgradable and has many options. a HX35 has so many options its hard to give you a ball park because it comes with about 5 different turbine housings. just get what i told you and you will be happy hands down. 12cm^2 turbine is what you need and if you feel you want more power later get a 14cm^2 or 16cm^2 turbine.
Cam79
Jun 27, 2003 09:59 AM
twkdCD595
Jun 28, 2002 12:45 PM
