Ran out of adjustment on my clutch cable
Old Oct 19, 2008 | 07:29 PM
ludesrv's Avatar
Default Ran out of adjustment on my clutch cable
I recently installed a transmission in the beater and I ran into an abnormal situation I have never encountered before. I am getting 3-4" of slack at the lever for the clutch cable. I have so much slack that I run out of adjustment when the clutch finally sees pressure. The engine and clutch are out of a 95 civic dx and the tranny is a dx cable tranny. I tried starting it up and moving it but it wouldn't even go into gear when in neutral and starting in gear would propel the car. I guess the pressure plate isn't getting enough push.
Anyone ever had this happen? I'm thinking of buying a HASport D series hydro mount kit and mounting my 80XXXkm 2000 civic ex tranny. If anyone has used that kit before drop me some info or pics.
Old Oct 19, 2008 | 07:34 PM
slammedeewagon's Avatar
Default Re: Ran out of adjustment on my clutch cable (ludesrv)
im confused you have the hydro clutch in there or the original one? what flywheel and clutch you got you use the one that goes with the trans so you have cable you use cable everything including flywheel...
Old Oct 19, 2008 | 07:42 PM
Pooby88's Avatar
Default Re: Ran out of adjustment on my clutch cable (slammedeewagon)
There is also an adjustment bolt near the top of the clutch pedal.
Old Oct 20, 2008 | 11:35 AM
ludesrv's Avatar
The clutch is from the 95 civic, including flywheel. The spline fit fine so I figured it was the same clutch. I'll have to check part numbers to make sure they are indeed different. The adjustment bolt on the clutch pedal is all the way out (taking up as much slack).
Anyone else ever had something like this happen?
Kid_SiR
Jul 16, 2011 12:10 PM
turbosivtec
12
Apr 26, 2009 11:55 AM
lopezchris21
11
Oct 30, 2008 09:24 PM
asmallsol
Aug 9, 2004 08:06 AM
92TEGGYGSR
Jul 12, 2004 04:56 AM
