What rear suspension can a CRX have?
Old Oct 19, 2008 | 06:37 PM
CRX_Honda's Avatar
Default What rear suspension can a CRX have?
I have found that the CRX can't have a ASR Subframe tie bar. But can the CRX have a rear lower tie bar? Rear sway bar of any sort? Im just curious as to what all rear suspension you can put on a CRX...
Old Oct 19, 2008 | 06:40 PM
redsi89's Avatar
Default Re: What rear suspension can a CRX have? (CRX_Honda)
thats a big 10-4 I upgraded the rear sway bar on my si with a ST 19mm sway bar
Old Oct 19, 2008 | 07:02 PM
BLU CIVIC's Avatar
Track Advocate
ASR does sell a kit for the 88-91 civic/crx
http://www.inlinefour.com/asr32rahoswk.html
Old Oct 20, 2008 | 02:58 AM
CRX_Honda's Avatar
Default Re: (BLU CIVIC)
holy cow they must've come out with that not to long ago? Does anyone care to post there set up? and if it made a difference to their car or not?
Old Oct 20, 2008 | 12:43 PM
vanrij's Avatar
Default Re: (CRX_Honda)
The ASR 32mm hollow sway bar makes a night-and-day difference on a CRX. The arms from the bar to the end-links are adjustable and you can use bars of different thickness to get the rear suspension exactly how you want it. It is also lighter than other aftermarket anti-sway bar kits (especially ST bar which is the 7/8" or 22.22mm not 19mm). The bars major character flaw seems to be that it does not clear factory routed exhaust, which shouldn't even really be a problem as this is a race design.
Modified by vanrij at 1:51 PM 10/20/2008
Modified by vanrij at 1:52 PM 10/20/2008
Old Oct 22, 2008 | 01:41 AM
gsxrallday's Avatar
i just placed an order for the whole kit witht he sub frame iw as wondering if it was hard to install
Old Oct 22, 2008 | 09:32 AM
vanrij's Avatar
Default Re: (gsxrallday)
If you can use a jack, jack stands, and a socket wrench installing the ASR bar is a breeze.
Old Oct 22, 2008 | 09:38 AM
EF'n Chris's Avatar
So from what I hear I won't clear my SP2...weak
Old Oct 23, 2008 | 08:58 AM
vanrij's Avatar
Default Re: (EF'n Chris)
Nope. If the design worked around a stock routed exhaust system it would be the best available bar IMO.
Old Oct 23, 2008 | 09:43 AM
pettyboy69's Avatar
nice kit i will probably buy one for my hatch!
Old Nov 5, 2008 | 12:58 AM
NlCK B's Avatar
Default Re: (vanrij)
have you driven the car with this sway bar yet?
if so under what driving conditions?
what spring rates are you using front and rear?
are you using a front swaybar?
are the koni's adjustable if so what setting are they at?
finally how does the car handle under hard loads does it want to over steer?
thanks allot ahead of time i'm considering buying this swaybar but i don't know whether or not it will be to stiff of a bar
Old Nov 5, 2008 | 04:07 PM
harlen's Avatar
post up some more pix of the asr set up
Old Nov 5, 2008 | 04:17 PM
Stefndogg's Avatar
Default Re: (harlen)
judging from experience (roadracing/autox with a crx), the st bar is prob more than enough for almost any situation. The asr is a nice piece but is overkill for anyone but the most extreme autox'r who needs that much rear stiffness..most people would prob kill themselves with that loose of a crx
Old Nov 5, 2008 | 04:18 PM
efsublime's Avatar
well i emailed asr about a week ago asking them when they were going to be available for ef's, and they responded back saying they are in progress on making the whole kit for da's, and ef's will soon follow. so i'm guessing that link is just for the swaybar kit.
Old Nov 5, 2008 | 06:42 PM
gsxrallday's Avatar
what exhaust are you using with this it seems like it would be real hard to put an exhaust on this set up i just put mine on but i dont know what exhaust would fit this ?
neozero999's Avatar
Default Re: (efsublime)
that ASR swaybar has to be the thickest ive ever seen. i just wanted to throw out there if you were in the market for a sway bar and your car isnt a track car, that shouldnt be your first choice! tuning your suspension from only your sway bar will only cause the car to be far too twitchy, as i have the st sway bar and on the stiffest setting time to time get snap oversteer. my three cents you can also put the integra sway bar which is a popular mod...
Old Nov 5, 2008 | 07:41 PM
gringo7718's Avatar
Default Re: (neozero999)
why not just get one for the crx?
Factory Rear Sway Bar Sizes:
CRX Si - 15mm
Civic Si - 13mm
Integra - 14.7mm
Old Nov 6, 2008 | 07:12 AM
efsublime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neozero999 &raquo;</TD></TR><TR><TD CLASS="quote">that ASR swaybar has to be the thickest ive ever seen. i just wanted to throw out there if you were in the market for a sway bar and your car isnt a track car, that shouldnt be your first choice! tuning your suspension from only your sway bar will only cause the car to be far too twitchy, as i have the st sway bar and on the stiffest setting time to time get snap oversteer. my three cents you can also put the integra sway bar which is a popular mod...</TD></TR></TABLE>
oh come on, snap oversteer is fun
Old Nov 6, 2008 | 10:01 AM
18psi sohc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efsublime &raquo;</TD></TR><TR><TD CLASS="quote">
oh come on, snap oversteer is fun </TD></TR></TABLE>
Umm, no snap oversteer is never fun, oversteer maybe.. I've been in a crx that snap oversteered and was cut in half at the firewall by a tree. Not such good times...
Old Nov 6, 2008 | 01:26 PM
vanrij's Avatar
Default Re: (NlCK B) (harlen) (gsxrallday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "NICK B" &raquo;</TD></TR><TR><TD CLASS="quote">have you driven the car with this sway bar yet?
thanks allot ahead of time i'm considering buying this swaybar but i don't know whether or not it will be to stiff of a bar </TD></TR></TABLE>
I’ve had several suspension configurations that included the ASR rear sway bar:
ASR rear, Progress front, ERS 350f 250r
ASR rear, Progress front, ERS 350f 450r
ASR rear, Hf front, ERS 350f 450r
ASR rear, Si front, ERS 350f 450r
I don’t recall all the various shock setting (it is kind of a multi-purpose car), but they are adjustable and were adjusted. There are four endlink mounting positions and you can use splined anti-sway bars with different wall thickness for adjustability (available from Speedway). I’ve used two bars with the kit (0.22 and 0.19 if I remember correctly). With the Progress bar up front I was still getting understeer at lower speeds and under quick driver inputs. With Si front bar and the 350f450r springs the rear end would break free just before the front (exactly how I like it), unless I was braking/accelerating aggressively. It was very controllable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "harlen" &raquo;</TD></TR><TR><TD CLASS="quote">post up some more pix of the asr set up </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "gsxrallday" &raquo;</TD></TR><TR><TD CLASS="quote"> what exhaust are you using with this it seems like it would be real hard to put an exhaust on this set up i just put mine on but i dont know what exhaust would fit this ? </TD></TR></TABLE>
I am not aware of any after-market exhausts that are compatible with this kit. Anyone let me know if I am wrong though. I was running a custom stainless exhaust that was almost straight through. This CRX ended up being my daily driver so I have since but a more forgiving anti-sway bar and exhaust system on it.
Old Nov 6, 2008 | 03:19 PM
efsublime's Avatar
Default Re: (18psi sohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18psi sohc &raquo;</TD></TR><TR><TD CLASS="quote">
Umm, no snap oversteer is never fun, oversteer maybe.. I've been in a crx that snap oversteered and was cut in half at the firewall by a tree. Not such good times...</TD></TR></TABLE>
well what i meant was intentionally going into a turn and "drifting". yeah i can understand snap oversteering unintentionally and going out of control. but thats why i'm still researching on what the most effective rear sway will be for a daily/track.
btw did you come out of the accident okay?
Old Nov 6, 2008 | 09:18 PM
NlCK B's Avatar
thanks for the info very informative i've been searching for info on this bar for the past week now
thanks again
Old Nov 9, 2008 | 08:38 AM
18psi sohc's Avatar
More or less, I had debris and cuts from the knees down. Had no shoes or socks when the emt's got their. Had a broken ankle that they put a screw in a few weeks afterward. The driver was in a lot worse shape tho. Two broken femurs, and alot of injuries to go along with it..
That bar is sick btw. I love that you can get different gauge bars to tune it.
Old Nov 9, 2008 | 10:14 AM
hatcht9x's Avatar
what is snap oversteering?
Old Nov 9, 2008 | 10:59 AM
18psi sohc's Avatar
Default Re: (hatcht9x)
It's when the vehicle oversteers violently and without warning.
