Crankshaft pulley
After many hours of banging my head against a wall, my neighbor brought over his 3/4in impact gun. Bolt came off in, no joke, two seconds.
Now I have run into yet another problem. How do I remove the drive pulley. Haynes says to just pull it off, but the dam thing wont just come off. Should i re-insert the bolt a ways and pry it off via the bolt?
Input helps. Thanks in advance
hit it with a rubber mallet hammer or LIGHTLY tap on it with a regular hammer. Then just pull on it. With enough pulling and tapping, it will come right off.
Do you mean the auxilary belts' pulley (just inboard of and touching the famous pulley bolt's washer) or the timing belt sprocket? My Civics' aux belts' pulleys always come off per the others' suggestions. Same for the sprockets, except for one time. For this one time I bought a set of cheap pullers from Harbor Freight, and one of these cheap pullers got it off. The puller's legs did not fit well, nonetheless, I finally got them to get a grip on the sprocket, and it came off. Pull very straight with no tilting.
arielb1
Jun 27, 2007 05:55 AM
omeara7
May 3, 2004 09:11 PM
EKB18BPR3
Jan 8, 2004 11:18 AM
