1992 Accord Abs light
Old Oct 19, 2008 | 10:46 AM
ed8_dx's Avatar
Default 1992 Accord Abs light
Hi, I just got a 92 accord 2 door 5 speed, and the abs light is on constantly. I was wondering if there was a way I could pull a code, to see as why it is on. I am really new to this body style honda, and do not know much about them. I searched already, but could not find a answer I was looking for, manily just found that most people unhook the system, but I would perfer to do it the right way, thanks in advance.
Old Oct 19, 2008 | 01:55 PM
ed8_dx's Avatar
Default Re: 1992 Accord Abs light (ed8_dx)
Anyone know??
Old Oct 19, 2008 | 04:03 PM
hondadude's Avatar
Jumper the blue 2 pin connector located at the top of the passenger side kick panel, turn on the key...watch the flashes.
The ABS light blinks a main code and sub code.
Such as 5 flashes then 2 flashes will be a code 5-2
Old Oct 19, 2008 | 04:04 PM
ed8_dx's Avatar
Default Re: 1992 Accord Abs light (hondadude)
awsome, I figured it was just like checking cel codes, but didn't know for sure, thank you very much, I really appriciate it.
Old Oct 20, 2008 | 09:05 AM
joc1394's Avatar
http://www.bba-reman.com/conte...codes
This should help you identify your problem once you have the code.
I have an intermittent problem with the ABS on my 92 Accord EX right now, so I've pulled the ABS pump fuse for the time being, but the light is setting because of a bad right rear sensor.
Good luck!
Old Oct 20, 2008 | 02:20 PM
ed8_dx's Avatar
Default Re: 1992 Accord Abs light (joc1394)
Hey, thanks for the link, very helpful
Old Oct 25, 2008 | 09:54 AM
gotusukin's Avatar
i have a 97 accord 2dr coupe 5speed..
wen i pull off my abs light goes on and stays on and if off wen i brake it will pulsate den light will come on to help brake.
Is there sumthing i should check to find out wat it might be.
tjwebber17
Suspension & Brakes
Jul 2, 2011 10:15 AM
TheOne
Apr 4, 2003 06:41 AM
VTECAcuraGSR
Aug 18, 2002 03:33 PM
