Gas Pedal Stuck on start up.
Old Oct 19, 2008 | 08:56 AM
legacy1644's Avatar
Default Gas Pedal Stuck on start up.
Hi everybody, I have been having this problem for a while and I never had chance to mention the problem on here but lately it seems to be getting worse. When I first start my car the gas pedal seems to stick on top. I have to either push it hard or tap on it to be able to relaese the pedal. It does this when I start the car at the first touch, It doesnt do it after then. Please let me know what you think might be the problem and what would be least expensive fix to it. The vehicle is 2000 accord 2.4 vtec. Thanks a lot.
Modified by legacy1644 at 10:02 AM 10/19/2008
Modified by legacy1644 at 11:44 AM 10/19/2008
Old Oct 19, 2008 | 10:45 AM
legacy1644's Avatar
bump
Old Oct 19, 2008 | 01:35 PM
P_Adams's Avatar
Default Re: Gas Pedal Stuck on start up. (legacy1644)
I don't believe the 6th Gen Accord uses an electronic throttle, so we're (read that as YOU) are going to have to check the Throttlebody, cable, pedal hanger operation.
Go to the throttlebody b4 starting it in the morning and try to manually work the throttle by hand. If you feel a bind as you work the shaft, it's possible it could be something as simple as cleaning the Throttle bore and Butterfly Valve. If you feel no bind check the cable operation and get under the dash and check for anything which might be interfering with the pedals operation.
P
Old Oct 19, 2008 | 03:01 PM
legacy1644's Avatar
Default Re: Gas Pedal Stuck on start up. (P_Adams)
ok.. I will give a try.. Any kind of cleaner or lubricant that you might recommend? Thanks
Old Oct 19, 2008 | 03:52 PM
hondadude's Avatar
There is a TSB about this problem;
Here is the answer to your problem.
Old Oct 19, 2008 | 04:08 PM
legacy1644's Avatar
So.. I should clean the throttle body ?
Old Oct 19, 2008 | 04:18 PM
hondadude's Avatar
Default Re: (legacy1644)
Berrymans B-12 and your roommates toothbrush,
Scrub out the ring of crud that is around the throttle plate.
Old Oct 19, 2008 | 06:11 PM
legacy1644's Avatar
Thanks a lot.. I had to do iacv cleaning to my 98 v6 accord which worked out very well. Thanks for all the advice.. you guys are great..
Old Oct 19, 2008 | 07:33 PM
P_Adams's Avatar
...sounds like an unabashed advertisement for Berryman's B-12! (Wonders to self if Hondadude holds a franchais on the stuff )
..but it does work.
P
Old Oct 19, 2008 | 07:48 PM
hondadude's Avatar
Default Re: (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">...sounds like an unabashed advertisement for Berryman's B-12! (Wonders to self if Hondadude holds a franchais on the stuff )
..but it does work.P
It will also remove permanant marker [sharpie] inks;
Old Dec 4, 2010 | 04:06 AM
3honda's Avatar
Will the above advice work on my '02 Accord, 2.4 vtec as well?
Old Dec 4, 2010 | 09:22 AM
clempot911's Avatar
Had to do it on our 2000 over the summer. I followed the TSB which required removing the TB, so a new gasket was involved - but it's worth a try doing it without all the disassembly, probably works the same. I used whatever TB cleaner they sold at the parts store - worked fine.
Same generation of car - so yes.
Dec 22, 2007 09:00 AM
NguyenDC2
Feb 3, 2007 09:59 PM
DarkShadow
Feb 5, 2005 03:19 PM
alb_accord
Dec 16, 2003 08:44 AM
95accordracer
Jan 11, 2003 07:43 AM
