Dumb Question: Changing Spark Plugs
Old Jul 29, 2002 | 07:12 AM
Flux's Avatar
Default Dumb Question: Changing Spark Plugs
I apologize if this is silly or stupid, but I am changing out my old spark plugs and I don't want to screw it up (I have never done this before). I have heard horror stories of overtightening the plugs or not tightening them enough...
Can somebody with the patience walk me through the best and proper way to change out the plugs...
Flux - who is always learning
Old Jul 29, 2002 | 07:13 AM
DutchITR1689's Avatar
Default Re: Dumb Question: Changing Spark Plugs (Flux)
Do you have a torque wrench?
Old Jul 29, 2002 | 07:15 AM
Flux's Avatar
Default Re: Dumb Question: Changing Spark Plugs (DutchITR1689)
yes
Old Jul 29, 2002 | 07:17 AM
Then you don't have to worry about anything!!!
I don't know the torque specs of the plugs now, but it's written in the user manual....
Old Jul 29, 2002 | 07:22 AM
CPR's Avatar
CPR
It's not a dumb question. I'd like to know also. Maybe if I get this spark plug thing right, I'll move on to a valve adjustment.
Old Jul 29, 2002 | 07:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I believe spark plugs get 14 ft-lbs torque.
Old Jul 29, 2002 | 07:52 AM
sgT's Avatar
sgT
Default Re: Dumb Question: Changing Spark Plugs (PatrickGSR94)
turn the new spark plug until it seats, then 1/2 turn
this only applies to NEW plugs.
Old Jul 29, 2002 | 08:33 AM
JPP's Avatar
JPP
Default Re: Dumb Question: Changing Spark Plugs (sgT)
It is also a good idea not to use the ratchet wrench until you screw the plug by hand (turn the ratchet extention and sprak plug socket by hand until the plug is seated). This is to prevent damaging the aluminium threads.
Old Jul 29, 2002 | 09:46 AM
Batoutahell's Avatar
Here are a few more tips.
1. Gap the plugs before you install them, do not trust the gap specs out of the box.
2. I like to use a very thin coat of anti-seize on the new plug threads.
3. When you screw in the new plugs, start them by hand without using a ratchet so you don't mess up the threads. I like to start screwing the plug counterclockwise until you feel the threads 'click', then screw it in clockwise.
4. Torque them down to factory spec (14 lb-ft??). It's in the owner's manual.
dleccord
22
Feb 10, 2010 03:43 PM
Lithel
Dec 9, 2008 09:09 AM
dohc_profile
Jan 7, 2006 02:07 PM
TeGGY_LS
Aug 11, 2004 12:08 PM
sexynuts(.)(.)
Jun 20, 2004 05:11 PM
