Valve cover bolt broke off........ ;-0
Old Oct 19, 2008 | 01:25 AM
jwicecold's Avatar
Default Valve cover bolt broke off........ ;-0
So I have a 94 accord project car Im workin on as we speak. I realized one of the valve cover bolts were broken off. I took the valve cover off and bought new bolts but I cant seem to extract the broken off part of the bolt out of the bolt hole...
Every drill bit seems to break that I use to drill into the broken bolt... Any ideas??? thanks
Old Oct 19, 2008 | 04:21 AM
P_Adams's Avatar
Default Re: Valve cover bolt broke off........ ;-0 (jwicecold)
Cut a slot in the top of the remaining stud using a hand grinder and a hobbiests cut-off wheel. I've got hanging around a dremel Moto-Tool and bit set which found it's way into my tool box from prior tinkering with RPV's. You can use a screwdriver and a pair of Vice Grips if you're lucky.
Applying some heat (and I mean "some (not a lot)) may help the extraction process.
Hopefully this stud isn't stripped in the bore and broke off.
P
Old Oct 19, 2008 | 04:43 AM
jwicecold's Avatar
Default Re: Valve cover bolt broke off........ ;-0 (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Cut a slot in the top of the remaining stud using a hand grinder and a hobbiests cut-off wheel.
P</TD></TR></TABLE>
Its not as easy as just cuttin a slot in the top of the remaining stud..... That is solid metal. I broke three bits trying to drill a hole in it to fit the extractor in. I need some sort of strong strong drill bit that is made in 1/2 to 3/4 inch thick.
I cant use vice grips because there is nothing to grab. It broke off flush where the hole starts.
Its not stripped I know that but it is in there pretty good. The dumb *** who tightened it did it way more then needed...
Old Oct 19, 2008 | 04:51 AM
P_Adams's Avatar
Then the only recourse is grinding the stud flat, center punching the stud and use a carbide tips drill bit using a slow rotational drill and some cutting oil.
(and a "Good" EZ-Out Bit.
I love the term "high speed bit" it's so mis-leading.
P
Old Oct 19, 2008 | 06:58 AM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Then the only recourse is grinding the stud flat, center punching the stud and use a carbide tips drill bit using a slow rotational drill and some cutting oil.
P</TD></TR></TABLE>
HOLY CRAP YOU'RE BACK?
Old Oct 19, 2008 | 11:05 PM
jwicecold's Avatar
P</TD></TR></TABLE>
Right on, thanks ill try that and see how it goes. your pretty well known on this forum huh??
Old Oct 20, 2008 | 02:44 AM
P_Adams's Avatar
I've been known to lerk (or is that lurch?) from time to time, yes
P
Old Oct 20, 2008 | 05:17 AM
lunarone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">
HOLY CRAP YOU'RE BACK?</TD></TR></TABLE>
. And at full swing! Look at all his informative posts already!
Old Oct 20, 2008 | 11:48 AM
professorman's Avatar
Default Re: Valve cover bolt broke off........ ;-0 (lunarone)
Yes, he has helped me tremendously already. I have gained a lot of knowledge.
Old Oct 20, 2008 | 12:06 PM
Duane_in_Japan's Avatar
Sears sells two types of extractors that fit directly into a reversible drill, so far, knock on wood, I have been able to get every broken stud out that was not an exhaust stud.
One set is just a hard left hand drill bit, the other is a left hand drill bit with the extractor built on to the drill bit. They come in pocket sized black cases with four bits each I think.
Old Oct 21, 2008 | 04:51 AM
jwicecold's Avatar
Default Re: Valve cover bolt broke off........ ;-0 (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Sears sells two types of extractors that fit directly into a reversible drill, so far, knock on wood, I have been able to get every broken stud out that was not an exhaust stud.
One set is just a hard left hand drill bit, the other is a left hand drill bit with the extractor built on to the drill bit. They come in pocket sized black cases with four bits each I think.</TD></TR></TABLE>
I think I found what you were talking about.. Just waitin for the next nice day so I can go try them!!! Ill let ya know if it works or not.
OH and P-ADAMS its lerk!! you got it, ha. thanks for your advice also. PPl say good things bout you on here..
SOHC_MShue
95
Dec 20, 2008 04:00 PM
jwicecold
Nov 1, 2008 01:02 AM
ramos2589
Feb 13, 2008 11:50 AM
renzema
Aug 29, 2005 09:42 AM
Geeq
Aug 3, 2005 02:46 AM
