I need help with my Swap !!
Old Oct 18, 2008 | 10:05 PM
DnG8787's Avatar
Default I need help with my Swap !!
I have a 1990 civic hatchback with a 4 sp manual transmission .. But a few days ago I got a d16y8 block & head with an edelbrock performer x intake manifold an 4 to 1 dc headers wat parts do I still need ??? Can I use any parts from my old motor can anyone please help me ???
Old Oct 19, 2008 | 06:09 AM
elmalouno's Avatar
Default Re: I need help with my Swap !! (DnG8787)
you will need an obd1 p28 ecu. an obd0 to obd1 jumper harness. a 4 wire oxygen sensor(denso part # 234-4099). maybe more depending on what you have...
did the engine come complete? does it have a distributor? clutch?
Old Oct 19, 2008 | 07:30 AM
DnG8787's Avatar
I came wit clutch no distributor and the alternator but it looks like I might need a new 1
Old Oct 19, 2008 | 07:38 AM
elmalouno's Avatar
Default Re: (DnG8787)
mine as well get a 92-95 civic ex distributor then also. an alternator if u need one other wise i think you can get started
Old Oct 19, 2008 | 07:43 AM
DnG8787's Avatar
Nice !! im gonna try to get sum pics so you can see … is there any parts that I can use from the old motor ???
Old Oct 19, 2008 | 07:45 AM
IndySporty's Avatar
Your alternator will fit on the new engine. You need to convert your car to MPFI also. Check the FAQ at the top of this forum to see how it's done
Old Oct 19, 2008 | 09:10 AM
DnG8787's Avatar
Im gonna put up sum pics just so u can have a look at what I got .. Im new in the Honda game .. Thanks !
Old Oct 19, 2008 | 05:34 PM
jiff312's Avatar
bump
Old Oct 19, 2008 | 08:04 PM
DnG8787's Avatar
Pics Of d16Y8
http://i196.photobucket.com/al...0.jpg
Pics of d16Z6
Old Oct 19, 2008 | 08:18 PM
SovXietday's Avatar
You will need an EX throttle body, you will need injectors/fuel rail/etc, you will need a chipped P28 with a Y8 timing map, you will need an OBD2 Dseries distributor, you will probably want a different transmission.
You will then need to convert the car into MPFI, wire the OBD2 distributor in, and tune the car correctly. A stock P28 will not run a Y8 well at all, trust me I just got over that whole debacle. Ugh.
The Z6 will be much easier to swap in.
D-NWI
Northwest (Sales)
May 14, 2010 11:50 AM
illestpnoy
Feb 15, 2010 07:43 PM
kylesmith3251
Jan 17, 2009 05:47 PM
sexyazz_ek
Jun 29, 2007 09:20 PM
spooled954door
Aug 14, 2006 06:01 AM
