Suspension & Brakes Theory, alignment, spring rates....
My Suspension Is making Sqeaky noise.
Old Oct 18, 2008 | 01:27 PM
dth0ng69's Avatar
Default My Suspension Is making Sqeaky noise.
Alright when ever I go over a little bumps or something my front left suspension makes little sqeaking noises. I poped my hood to check, i pushed my car down and up and you can hear the same sqeaking noises. The little ring thing on the suspension isn't tighten down because of the screw that doesn't screw down,
video ...
note: squeaking is actually louder in real life, and wen you drive.
this is the screw that won't screw because i probably stripped it wen i tightened it with a torque wrench, which i heard you arent suppose to use to tighten it.
So should i replace that screw? if so where could i get one?
thanks in Advance
Old Oct 18, 2008 | 06:25 PM
FlatBrokeHatch's Avatar
Default Re: My Suspension Is making Sqeaky noise. (dth0ng69)
Put an allen wrench in the top to hold it from turning, then tighten the nut.
Old Oct 18, 2008 | 08:30 PM
Targa250R's Avatar
be professional
Default Re: My Suspension Is making Sqeaky noise. (FlatBrokeHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBrokeHatch &raquo;</TD></TR><TR><TD CLASS="quote">Put an allen wrench in the top to hold it from turning, then tighten the nut.</TD></TR></TABLE>
Yep. The OE damper rod has a hex socket to allow you to use an Allen key to keep it from spinning while you turn the nut with a wrench.
Old Oct 18, 2008 | 09:04 PM
Linh.'s Avatar
Default Re: My Suspension Is making Sqeaky noise. (Targa250R)
My integra is having squeeky noises also when i go over speed bumps. Can't figure it out.
Old Oct 19, 2008 | 06:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My front suspension squeeks, but it is because of cheap@$$ rubber bushings on my cheap@$$ replacement front upper control arms.
Old Oct 20, 2008 | 05:55 PM
alphalanos's Avatar
Default Re: (PatrickGSR94)
Yeah Omni power bushings suck.
Old Oct 21, 2008 | 07:35 AM
Community Builder
Default Re: (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">Yeah Omni power bushings suck.</TD></TR></TABLE>
haha wat? No camber kits here. I have some cheap OE-style replacement upper arms I got because I wanted new ball joints.
It came with new bushings on the inner mounts, but I may just swap back over to the original bushings of my old OE arms.
dth0ng69
15
Nov 11, 2008 11:14 AM
kharned08
Honda Civic (2001 - 2005)
Mar 20, 2008 08:37 PM
akteamster
Nov 18, 2004 07:48 PM
nugget8000
Jan 22, 2002 01:13 PM
