So who makes a spacer that will slant a turbo?
Old Oct 18, 2008 | 11:39 AM
Trojan Man's Avatar
No Sales Forums
From: Reading the Chronicles and Blowin Trees in Virginia
Default So who makes a spacer that will slant a turbo?
OK, I'm having the normal B16-T problem. Got my manifold/turbo off a LS and try it on the B16. Thats a no go. My friend told me about some sort of spacer type deal (thats kind of like a elbow on a wastegate) that you can put between the manifold and turbo and it will slant the turbo the way you want. If I can find it in time before I sell my **** and just get a inline pro manifold and a SC61, then I'll get it and try to get my set-up to work.
Thanks.
Old Oct 18, 2008 | 04:40 PM
yakuza's Avatar
Default Re: So who makes a spacer that will slant a turbo? (Trojan Man)
Just get a machine shop to custom make you a flange that sits between your turbo and manifold. Where does exactly the turbo touch on your engine? Pictures would help !!!
Old Oct 18, 2008 | 07:48 PM
blinx9900's Avatar
Default Re: So who makes a spacer that will slant a turbo? (yakuza)
grind block webbing. thats what most of us do.
Old Oct 19, 2008 | 09:07 AM
Redcoupe's Avatar
Default Re: So who makes a spacer that will slant a turbo? (blinx9900)
We tested his manifold/turbo on my already grinded B16a.
Trojan. I still think you should change manifolds but you can order a header flange off ebay. Use longer and STRONGER bolts to hold the turbo up.
Old Oct 19, 2008 | 03:33 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redcoupe &raquo;</TD></TR><TR><TD CLASS="quote">We tested his manifold/turbo on my already grinded B16a.
then he has the wrong turbo, sounds like its a Garrett T3/t4 or similar copy, if that's the case he has to grind A LOT and i would not recommend it.
Old Oct 19, 2008 | 03:38 PM
Trojan Man's Avatar
No Sales Forums
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
then he has the wrong turbo, sounds like its a Garrett T3/t4 or similar copy, if that's the case he has to grind A LOT and i would not recommend it.</TD></TR></TABLE>
Um, yeah. Thats why I made this topic? Its 100% a Precision turbo. I'm not trying to grind ALOT. I want to get a spacer thing and move the turbo outside and grind a little.
Old Oct 19, 2008 | 05:08 PM
drumking15's Avatar
what about a pandusky sports flange...they make one for a t3 style flange to rotate a turbo on the cast spa topmounts...it should work the same way for yours
Old Oct 19, 2008 | 05:11 PM
Trojan Man's Avatar
No Sales Forums
Default Re: (drumking15)
Any further info on where I may be able to find this? I'm really looking for a spacer type deal because this will be going on a log manifold.
Old Oct 19, 2008 | 05:19 PM
CoreyR's Avatar
Default Re: (Trojan Man)
are you trying to put a 4 bolt sc61 on a cast mani?
Old Oct 19, 2008 | 05:23 PM
Trojan Man's Avatar
No Sales Forums
Default Re: (CoreyR)
Nope, It's a T3/T04e Precision .57 trim .63 A/R.
If I upgrade and can't figure out how to get this set-up to work, I'll be upgrading to a SC61 and a inline pro manifold.
Old Oct 19, 2008 | 06:30 PM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trojan Man &raquo;</TD></TR><TR><TD CLASS="quote">Nope, It's a T3/T04e Precision .57 trim .63 A/R.
If I upgrade and can't figure out how to get this set-up to work, I'll be upgrading to a SC61 and a inline pro manifold.</TD></TR></TABLE>
ok but does it have a 4 bolt exhuast housing?
Old Oct 19, 2008 | 07:28 PM
Trojan Man's Avatar
No Sales Forums
Yes.
Old Oct 19, 2008 | 08:30 PM
CoreyR's Avatar
thats your problem. those cast mani's only work with 5 bolt housings. you would need a large spacer on the head flange to clear with a 4 bolt.
Old Oct 20, 2008 | 07:39 AM
neoc03's Avatar
Ok not trying to thread jack, but I ran into the same problem yesterday. So are you saying you can just get a exhaust flange, and use it as a spacer? I am running the InlinePRO T3 SS, and I have a T3/T4 .60
Old Oct 20, 2008 | 07:44 AM
Trojan Man's Avatar
No Sales Forums
Default Re: (neoc03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neoc03 &raquo;</TD></TR><TR><TD CLASS="quote">Ok not trying to thread jack, but I ran into the same problem yesterday. So are you saying you can just get a exhaust flange, and use it as a spacer? I am running the InlinePRO T3 SS, and I have a T3/T4 .60</TD></TR></TABLE>
Damn really? Yeah thats what I'm thinking. Just get a flange and then shave down so it slopes it out some but make sure it's smooth. Thats my guess.
Old Oct 20, 2008 | 08:32 AM
CoreyR's Avatar
you can use a headflange to space it away from the head, youll need longer studs to do so. the problem with getting a "slanted" flange is that there isnt a way to get the threads straight to bolt it up.
FW_EJ8
Nov 28, 2007 08:42 PM
BoostedVtecGsr
Aug 25, 2004 06:11 PM
LiLOtaku
Mar 12, 2003 12:21 PM
DIY_Racing
Jan 1, 2003 05:49 PM
