IM spacer and balance shaft removale
Old Oct 18, 2008 | 08:25 AM
Acidcrakker's Avatar
Default IM spacer and balance shaft removale
Im just wondering if the black trax spacer is hallowed out or if its just another butterfly plate with no butterfly valves.
Im seeing 2 on there site, and Im wondering if it really makes that much of a diffrence if its hallowed out or not.
Also about the balance shaft removal kit, what does the kazienspeed kit come with? And what does it block off?
Old Oct 18, 2008 | 11:05 AM
mattsnooz's Avatar
Default Re: IM spacer and balance shaft removale (Acidcrakker)
You still in the game? I thought you bailed?
The black trax spacer (the one I've seen) is just hallowed out. I'd just get the hallowed out one.
As far as the kazienspeed kit, budumbump because I ain't ever seen it.
Hows the non honda holding up anyway? lol
Old Oct 18, 2008 | 11:12 AM
Default Re: IM spacer and balance shaft removale (mattsnooz)
Nah, Im just floating around now.
Im made my own Spacer out of an extra butterfly spacer I had lying around.
As for the Kazein kit, ive been looking all over for what the kit blocks off so I could go to home depo and see if I can create my own kit.
The Tc is okay but its so damn slow. I did however upgrade the whole suspension on it.
Old Oct 18, 2008 | 08:42 PM
i love it 50 views and matt snooze asked me about the gay *** tc.
i know one of you is holding back useful information here based on the kazien speed kit
Old Oct 18, 2008 | 10:10 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry, you won't be able to reproduce the kit from Home Depot. There are 2 precisely measured plugs and an oddly shaped machined block-off plate. Plus other small plugs and taps....those you might be able to find.
Old Oct 19, 2008 | 04:57 AM
Default Re: IM spacer and balance shaft removale (Hawkze_2.3)
Does anyone have a picture of what the kit plus up? Does it plug up the holes on the block where the balance shafts come out of.
Im also thinking some JB Weld might work. If anyone has a diagram of the instructions on how its installed somewhere, Id like to see.
Old Oct 19, 2008 | 05:52 AM
pheurton-skeurto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have a picture of what the kit plus up? Does it plug up the holes on the block where the balance shafts come out of.
Im also thinking some JB Weld might work. If anyone has a diagram of the instructions on how its installed somewhere, Id like to see.</TD></TR></TABLE>
id really like to have this info as well. if nothing else just to know that the $100+ im going to spend for the bs removal kit is worth something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry, you won't be able to reproduce the kit from Home Depot. There are 2 precisely measured plugs and an oddly shaped machined block-off plate. Plus other small plugs and taps....those you might be able to find.</TD></TR></TABLE>
im confident that i could replicate the plugs in some way. is the weird shaped block off plate something that could be reproduced with a steel plate? if nothing else, maybe Kaizenspeed would sell us just the weird shaped block off plate.
Old Oct 19, 2008 | 07:20 AM
A Blue Lude's Avatar
https://honda-tech.com/zerothread?id=2391818
Old Oct 19, 2008 | 05:33 PM
Default Re: IM spacer and balance shaft removale (A Blue Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A Blue Lude &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=2391818</TD></TR></TABLE>
that thread is perfect. exactly what i was looking for. thanks.
Old Oct 19, 2008 | 05:37 PM
Default Re: IM spacer and balance shaft removale (pheurton-skeurto)
Instead of going through all that trouble of making the taps, why not just use JB Weld over the smaller holes, and JB weld the bigger holes with the frezze plugs?
Old Oct 19, 2008 | 06:46 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pheurton-skeurto &raquo;</TD></TR><TR><TD CLASS="quote">
im confident that i could replicate the plugs in some way. is the weird shaped block off plate something that could be reproduced with a steel plate? if nothing else, maybe Kaizenspeed would sell us just the weird shaped block off plate. </TD></TR></TABLE>
From Home Depot though?
Old Oct 20, 2008 | 02:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Instead of going through all that trouble of making the taps, why not just use JB Weld over the smaller holes, and JB weld the bigger holes with the frezze plugs?</TD></TR></TABLE>
i just dont know if id trust JB Weld to hold up over time. i guess it is an option though.
From Home Depot though? </TD></TR></TABLE>
ha! sure home depot works...
DerekHollister
Mar 23, 2016 05:44 PM
olehtheukie
Mar 18, 2016 06:46 AM
Innovation
Mar 4, 2011 07:08 AM
LukieLuc
Mar 25, 2007 07:59 AM
