fuel pressure problem?
Old Oct 18, 2008 | 08:25 AM
Rus01's Avatar
Default fuel pressure problem?
my 1990 accord wont start right away when first started. if i cycle the fuel pump once then it starts right away. this only happens in the morning then good for the rest of the day. any sug?
Old Oct 18, 2008 | 09:06 AM
P_Adams's Avatar
Default Re: fuel pressure problem? (Rus01)
The Master Relay (that funky dual duty thingie) may possibly be on the way out.
While it traditionally seems to fail during unbearably hot days, it does supply power to two critical components.
The ECM (Engine Brain Box as some recyclers like to call it)
The Fuel Pump.
During the start-up proceedure the pump's actuated via the ignition switch thru the
Master Relay. Once it's running, the pump is actuated by (as I recall) the Oil Pressure sensor switch.
P
Old Oct 18, 2008 | 09:14 AM
hondadude's Avatar
Try this; turn on the key, wait for the CEL to go off, then crank.
Mr Frustrated
Jun 7, 2017 12:10 AM
ridekona93
Nov 21, 2011 07:03 PM
Scotty_1988crxsi
Feb 18, 2009 07:33 PM
poppypizza
Apr 25, 2008 11:34 AM
papa_smurf
Aug 9, 2006 02:04 PM
