Wierd acceleration issue Tranny slipage?
Old Oct 18, 2008 | 06:36 AM
accord99power's Avatar
Default Wierd acceleration issue Tranny slipage?
On a regular stock 99 honda accord with manual transmission. How would you diagnosis this problem.
First started in 4th and 5th gears if i gave the car to much gas the rpms would go up faster then the speed, kinda like a automatic tranny slipage. where the rpms go up alot faster then you move. The wierd part is 1-3 gears worked fine. The the 3rd gear started acting the smae way, now 2nd gear is starting to do it.
seems like if i give it to much gas around 4k is when it acts like that.
I threw out the clutch because its engaging and disengaging fine.
i havent checked the manual tranny fluid yet, anyone have any ideas?
Old Oct 18, 2008 | 07:43 AM
TheMuffinMan's Avatar
He knows where you live!
Change the fluid and see how that goes
Old Oct 18, 2008 | 07:46 AM
hondadude's Avatar
Default Re: Wierd acceleration issue Tranny slipage? (accord99power)
You are sure the clutch is good?
pull on the parking brake, put it in 5th gear at idle and slowly let off the clutch.
The engine should stall out,; this is a good test for clutch slippage.
The other test I do is drive on the highway in 5th, hold the gas pedal steady, then bump the clutch on and off. The RPM should stay even.
Old Oct 18, 2008 | 07:59 AM
Never heard of those tests but def. sounds like a good way to test, thanks hondadude
Old Oct 18, 2008 | 08:05 AM
Default Re: Wierd acceleration issue Tranny slipage? (hondadude)
Hey honda-dude thanks for the reply, i am not sure aBout the clutch, the clutch was replaced about 2 years ago with a cheap advanced auto parts one if i remember right. didnt think i was ever gonna boost is why.
i will try these tests and report back,
to give you more of a feel of whats going on, its like losing traction but im really not. rpms going up but still increasing alittle speed.
Old Oct 21, 2008 | 07:19 AM
my rpms dropped like 5-600 on the highway test, start lookin for another clutch?
Old Oct 21, 2008 | 09:10 AM
P_Adams's Avatar
you were too quick on the trigger eliminating the clutch because, (wait for it)
it IS the clutch causing the problem.
There is nothing inside the Manual transmission which would allow it to slip. It's all gears, shafts and shift forks in there.
Your clutch (however) is all about slipping. Every time you shift, it slips (to some degree).
While you're addressing the new Clutch Pressure Plate, Disc and Throw-out Bearing issue, pay particular attension to any fluid (bad) which you might find in the bellhousing. Engine oil (Rear Main Seal) or Hydralic Fluid (Clutch Slave Cylinder) will rapidly ruin a clutch.
P
Old Oct 21, 2008 | 09:33 AM
Default Re: Wierd acceleration issue Tranny slipage? (P_Adams)
thanks p_adams good info! I guess i eliminated it becasue it was slipping in gear under acceleration around the 4k rpms, i dont know much about them, I was thinking well if its in gear then the clutch did its job, i need more transmission experience huh,haha.
Old Oct 21, 2008 | 09:50 AM
P_Adams's Avatar
Don't diss yourself, no one's expected to know everything. You were smart (and brave) enough to ask.
The crime would have been if you hadn't.
P
accord99power
Oct 18, 2008 11:33 AM
LSeeper
Sep 8, 2004 03:47 AM
snatch13
Dec 12, 2003 08:25 AM
XES
Jul 18, 2003 09:22 AM
aznmc16
Jan 1, 2003 02:39 AM
