BROKE my clutch pedal has this hapenned to anyone?
Old Oct 17, 2008 | 05:08 PM
ef9vlad's Avatar
Default BROKE my clutch pedal has this hapenned to anyone?
so there i was driving my car and i noticed it was starting to feel really hard to put it in gear to a point were it had to fall in to gear just to drive so i pulled over and turned my car off and checked it out and it looked cool so i hop back in and now it wont start i took a look up under the dash were the clutch pedal is and i broke that bar that goes across at the top i hope someone knows what im talkin about cause its hard to explain unless u take a look but any segestions ? ur help is apreciated
Old Oct 17, 2008 | 05:20 PM
johnnyonth3spot's Avatar
Default Re: BROKE my clutch pedal has this hapenned to anyone? (ef9vlad)
Its a common thing mostly with aftermarket clutches, just go to the junk yard and get one or if you can weld or know someone that can put some fat beads on it and make it stronger
Old Oct 17, 2008 | 05:23 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: BROKE my clutch pedal has this hapenned to anyone? (johnnyonth3spot)
Let me guess you are not an SI?
CRX Toad has the pictures and we've chatted about this as I've had this problem myself. Non SIs oddly had a different pedal set, and it was weaker.
I've re welded mine and it's stronger then sin.
Old Oct 17, 2008 | 05:30 PM
ef9vlad's Avatar
Default Re: BROKE my clutch pedal has this hapenned to anyone? (***$nyper)
awww i see thanks guys umm a link to how to get the dang thing off would be very helpful please
Old Oct 17, 2008 | 05:31 PM
julioboostamante's Avatar
doh! that sucks! hasnt happened to me yet, but i dont think it will be long before it does. then again i dont drive the sedan much.
ef9vlad's Avatar
ya my cars a dx
Old Oct 17, 2008 | 05:56 PM
sgallagher's Avatar
Nice the SI's are stronger?!?! I'm glad I pulled my pedal set out of an SI at the yard!
Old Oct 17, 2008 | 06:48 PM
clumsyfool's Avatar
wow that sounds kinda scary.
makes me trip about my 6 puck in my std..
Old Oct 17, 2008 | 07:48 PM
13g-crx's Avatar
Default Re: (clumsyfool)
I've broken one out of an si and one out of a hf. Had to change one in a Sears parking lot.
Old Oct 18, 2008 | 08:21 AM
honda.lioness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9vlad &raquo;</TD></TR><TR><TD CLASS="quote"> umm a link to how to get the dang thing off would be very helpful please </TD></TR></TABLE>
Do a yahoo search of this forum using:
"clutch pedal" site:honda-tech.com
Many hits come up with info on replacing it.
Old Oct 18, 2008 | 01:33 PM
FSS13foxtrot's Avatar
theres 4 bolts holding the whole assembly on near all four corners of the plate, towards the firewall....disconnect the clutch cable, then gas pedal etc, then go from there....if im not mistaking, bump
Old Oct 18, 2008 | 04:13 PM
B20_CRX's Avatar
My pedal broke off on the Highway, and snapped the clutch cable too!, what a pain in the *** to replace. so cramped
Old Oct 19, 2008 | 11:05 PM
i_VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9vlad &raquo;</TD></TR><TR><TD CLASS="quote">so there i was driving my car and i noticed it was starting to feel really hard to put it in gear to a point were it had to fall in to gear just to drive so i pulled over and turned my car off and checked it out and it looked cool so i hop back in and now it wont start i took a look up under the dash were the clutch pedal is and i broke that bar that goes across at the top i hope someone knows what im talkin about cause its hard to explain unless u take a look but any segestions ? ur help is apreciated </TD></TR></TABLE>
The same thing happened to my CR-X. Mines an Si too! Heres a picture of what happened. Some advice? Take off the dashboard! Some people might say that its too much work to take it off, But its NOT! It's more work trying to unscrew the bolts with the dash on! Check out my picture, Maybe this will clarify what your talking about...
Old Oct 19, 2008 | 11:15 PM
143MYVTECEF's Avatar
Default Re: BROKE my clutch pedal has this hapenned to anyone? (i_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Same exact thing happened to me. Just take the steering column out for easier access and i believe there is around 6-8 nuts holding the pedal assembly on. Disconnect clutch/brake/gas and it pulls right out. Then reverse process.
Im surprised this is such a common occurrence. If i would have known that i would have done a write up on it.
Old Oct 20, 2008 | 12:31 AM
K2e2vin's Avatar
I wonder if DA assemblies could be modified to work. They seem much more beefy.
Alope
Apr 10, 2014 06:55 AM
LS_VTECteggy
Dec 21, 2009 05:22 AM
hybrider
Aug 3, 2002 06:20 PM
hybrider
Aug 3, 2002 12:53 PM
flip1199
Jul 29, 2002 02:14 PM
