Transmission & Drivetrain Gearboxes, Differentials, Clutches
No Reverse after LSD install, Need help in solving this problem
Old Oct 17, 2008 | 01:38 PM
ghostsi69's Avatar
Default No Reverse after LSD install, Need help in solving this problem
To make a long story short since it has been awhile since i did the Quaife LSD install. So after destroying my oem diff i replaced it with a quaife lsd, i did plunty of research before i did the job. Problem is that after i got everthing reinstalled and into the car, by the book and a DIY i found on here. I found that i couldnt get it to go into reverse, all other gears work fine and shift smoothly. Now I can get it to go into reverse but i have to hold it into were reverse is but the shifter does no go into reverse itself if that makes sense. The car well reverse if i hold the shifter into the position were reverse should be but the shifter does not fall into gear itself. And the go will reverse like i said but will pop out so i have to feather the clutch and reverse slowly.
So I am about to go ahead and remove the trans again to see if i can find the problem and fix it but i am wondering if someone can point me in the right direction on were to look.
Old Oct 17, 2008 | 01:39 PM
ghostsi69's Avatar
Default Re: No Reverse after LSD install, Need help in solving this problem (ghostsi69)
Forgot to mention this is a 2000 civic si S4 trans
Old Oct 18, 2008 | 09:37 AM
ghostsi69's Avatar
anyone have any ideas about this. I got the tranny out today and will be pulling the case apart tomorrow so I am really looking for some kind of input.
Old May 27, 2009 | 07:45 PM
lzmperu's Avatar
did you ever find the problem with the tranny????
thanks
Old May 28, 2009 | 09:19 AM
Evs-One's Avatar
Solbros Owns Me
Reverse idler gear is upside down.
Why don't people bench shift their transmissions before installing it into the car???? Could have saved yourself 6 hours and a lot of headache.
Old May 28, 2009 | 04:04 PM
Honda Bull's Avatar
A friend of mine brought me a trans that they tore apart when I was just starting to work on trans but didn't know what everything looked like 'normal'. I went to close the case, doing everything how the trans was given to me, but the case wouldn't close. Turned out the reverse gear was upside down. lol That's the last time I mess with anything that someone else tore apart for quite some time.
Again, one time I didn't a couple years ago and put a trans I replaced parts in into my personal car. Got in and had no 3-4. Freaked out and pulled the trans back out. Turns out I jammed the ball and detent spring with the shift fork - a fix that could have been done without pulling the trans. lol I was so pissed.
Old May 28, 2009 | 06:07 PM
Mista Bone's Avatar
D Tranny Guru
I have a old clutch on the wall for bench shifting as well as a shift linkage handle.
FreaQ
10
Mar 12, 2009 08:34 AM
Boosted_Coupe
Apr 28, 2008 05:58 PM
.adam.
Apr 18, 2008 05:55 AM
fastasssr20
15
May 30, 2007 12:07 PM
MtnCRX
63
Oct 18, 2006 05:03 PM
