AC question
Old Oct 17, 2008 | 12:21 PM
jrs98's Avatar
Default AC question
I bought my 1998 honda civic about 3months ago and everything's been working great. Just this past week I haven't been using my ac since the weather has been a lot cooler, but now it's freaking hot again. I go to turn on my A/C today and the cold air wasn't blowing any cold air it was more warm than anything. What could be the possibly be the issue with the a/c would it just need a recharge? Any suggestions would be awesome thanks.
Old Oct 17, 2008 | 12:25 PM
Former User's Avatar
Default Re: AC question (jrs98)
With the A/C button pushed, does both the condenser fan run and the compressor clutch engage?
Old Oct 17, 2008 | 12:35 PM
jrs98's Avatar
Default Re: AC question (RonJ@HT)
yes it does.
Old Oct 17, 2008 | 12:37 PM
92egstevie's Avatar
take it to kwik-fit they can try a re-charge if it works its 44.95 if it doesnt theres no charge i know this because i run a kwik-fit depot lol but havent came across a honda that a recharge hasnt worked on
Old Oct 17, 2008 | 12:38 PM
I_R_Baboon's Avatar
^^ check what RonJ@HT said as your a/c system usually doesn't just crap out on you without running it for only a week. I've gone almost a whole winter without turning on my a/c and when I did it worked great the first time.
Old Oct 17, 2008 | 12:40 PM
You may have a refrigerant leak. If you have a manifold gauge set, you can verify that the R134a refrigerant pressure is low in the system and safely recharge it. You may want to refill with refrigerant containing a special dye that allows you to detect the location of the leak with a UV light.
Old Oct 17, 2008 | 01:46 PM
92egstevie's Avatar
SAVE YOURSELF ALL THIS HASSLE THE MACHINE WE HAVE CAN DETECT LEAKS
no air-con charge no fee and if it works then bobs your uncle
Old Oct 17, 2008 | 01:48 PM
92egstevie's Avatar
Default Re: AC question (92egstevie)
sorry just realised everyone whos on this topics in a different country lol awell would have worked if you were in scotland lol
Old Oct 17, 2008 | 03:51 PM
honda.lioness's Avatar
Lots of possibilities, but one to consider is the solder joints in the heater control unit circuit board are failing. See http://honda.lioness.googlepag...oning . This has come up with others a few times here at honda-tech.com .
Sandra13368
Honda Civic (2016 - Current)
Jun 6, 2017 09:15 AM
emmanmin
Mar 20, 2017 07:10 PM
PimpViking
Mar 14, 2007 02:10 AM
xrupertx
Jun 28, 2004 03:47 PM
