Well the B20 A/C braket work with a single cam compressor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solturbob16sol »</TD></TR><TR><TD CLASS="quote">it will but only 2 of the compressor bolts will fit</TD></TR></TABLE>
two bolts across like diagonal or straight across? or should i just save the hassle and by the del sol bracket for a b16?
If thats what your trying to do, Then yes you can use a CRV bracket with a civic pump. The CRV uses a civic AC Comp anyways. Now if your gonna try and bolt that crv bracket to a sohc I dont think that will work. It will work on any B-Series. Yes you can use the Del Sol but its more expensive than the CRV. The CRV Comp Bracket New is only like $89.
hatchdrvr
21
Jul 18, 2002 04:33 AM
CivicEx95
Apr 25, 2002 01:04 PM
