help please.. axle leak
i just replaced the throwout bearing and installed everything back together. when i went to add oil it kept leaking out the driver side axle. its pushed in all the way but it keeps leaking. i took out the seal inside the tranny and it seemed fine. does anyone know what it might be?
As mentioned above, a damaged seal seems most likely. Also, is the driver-side axle fully inserted into the transmission? There should be only a small gap between the inboard joint and transmission.
xXxHOLYMANxXx
Oct 17, 2011 10:07 AM
