B16 Block/Crank Ls/c1 Rods/Pistons?
Old Oct 16, 2008 | 10:46 PM
CTR_B's Avatar
Default B16 Block/Crank Ls/c1 Rods/Pistons?
Is it possible to use Ls/C1 rods and pistons safely in a B16 block with a B16 crank?
Don't need any [freak]ed up answer or smart *** comment just a honest answer please
Old Oct 17, 2008 | 08:26 AM
CTR_B's Avatar
Default Re: B16 Block/Crank Ls/c1 Rods/Pistons? (CTR_B)
TTT
Old Oct 17, 2008 | 08:52 AM
Salsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR_B &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to use Ls/C1 rods and pistons safely in a B16 block with a B16 crank?
r/s x stroke= rod
1.74 x 77.4 ~ 134.68
1.56 x 87.2 ~ 136.02
The b16 block is shorter than the LS and it has shorter rods... looks like u'r pistons will be sitting out of the hole about 2 mm (guestimation). Maybe custom piston with the pin moved up would work.
IDK if the gsr rods have the same BE width as the B16 rods though..
Old Oct 17, 2008 | 03:12 PM
CTR_B's Avatar
Default Re: B16 Block/Crank Ls/c1 Rods/Pistons? (Salsa)
Even with a B16 crank it would still be too long?
Old Oct 17, 2008 | 04:12 PM
Salsa's Avatar
Straight from Eagle...
B16a Rod Length - 5.290"
LS Rod Length - 5.394"
GSR rod Length - 5.430"
LS would be the closer one BUT.....
.104" = 2.64 mm higher than the normal B16 piston position
damn I was close...
c-speed calculator has the stock B16 piston as .020" under the deck. with the LS rod u will be .084" out of the hole and the OEM 3 layer headgasket is only .029" so i think the piston will hit the head....c-speed says 14.5:1 compression with b16 pistons (6 cc dome LOL)
Old Oct 17, 2008 | 04:15 PM
CTR_B's Avatar
lol damn,
But thanks for looking that up for me
Old Oct 17, 2008 | 04:19 PM
Salsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR_B &raquo;</TD></TR><TR><TD CLASS="quote">lol damn,
But thanks for looking that up for me</TD></TR></TABLE>
no problem dood
CTR_B
Nov 9, 2008 05:54 PM
dc4b20
May 9, 2008 12:46 PM
NOman0608
Mar 16, 2008 06:57 PM
sonicivic
Jun 30, 2007 04:24 PM
GumballNA
Aug 5, 2004 02:49 PM
