Sorry Newbie first post - Will 185/75R14's fit a 1990 civic hatch?
Hey sorry this is my first post. We're going to have to drive our civic this winter and I wanted a bit more ground clearance. Stock tire is 175/70r13 and I thought with the size above I'd gain 1" and some ground clearance but I want to make sure it won't rub (or not much).
Car is a 1990 civic DX hatch with a b18a1 5sp.
Cut coils right now(previous owner) but I'm replacing the front springs with stock hatch ones (or sedan one i I can find some)
195/60/14 is 23.2" diameter
Stock is 22.6
185/75/14 is 24.9 Almost 2" taller then 195/60r14's
Stock is 22.6
i am lowerd 3 inches and i have no problems with rubbing at all so if u went to stock u would be fine if i am 3 inches lower then wat ur going to be running. my tires are also wider then yours too so u will be fine i work at ted wiens it is a tire and auto shop i know the diff in the tires
I had 89 Civic wagon 1.5L.
I tried 185/80-r13, It is 24.7" diameter, Stock is 22.7", It did lightly touch my wheel wall while driving in curve, so I changed to bigger offset rim with 185/80/R13, it ran fine with this
the b man
Jun 13, 2007 04:34 AM
