Please assist, h22 into a 95 ex problems
Old Oct 15, 2008 | 06:01 PM
itsmeek's Avatar
Default Please assist, h22 into a 95 ex problems
I have acquired a 1995 ex w/h22 swap. I have the two below CEL's.
14-IAC Valve (Idle Air Control)
defective circuit or unplugged / defective sensor
22*- Accord Civic CRV CRX Del Sol Odyssey Prelude
VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
I have the p13 ecu, what do I have to rewire/plugin or ground and reroute to make this car run like it should? Right now I have no VTEC and uneven idle if driven or if the AC is turned on.
thanks
meek
Old Oct 15, 2008 | 09:51 PM
momstaxi's Avatar
Default Re: Please assist, h22 into a 95 ex problems (itsmeek)
are you sure the two plugs aren't swapped? both those sensors use the same style/shape plug, its a possibility if the previous owner hacked the engine harness for the swap
itsmeek
Oct 9, 2008 09:11 AM
joshb3480
Oct 5, 2006 06:57 PM
hondatuningboi96
Aug 24, 2006 03:11 AM
Sabbotage
Aug 2, 2004 08:51 PM
mrpaperpaper
Jul 16, 2004 03:18 AM
