Question about the MPFI manifold have a pic
Preparing to do the MPFI swap on my hatch and noticed something was missing from the bottomside of my manifold. Can anyone tell me what is supposed to bolt here?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicmulisha »</TD></TR><TR><TD CLASS="quote">its called the fast idle solenid valve it is a black circle thing with wires coming out</TD></TR></TABLE>that is correct - Fast Idle Control Valve
i'll let ya know in tonight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cougar289 »</TD></TR><TR><TD CLASS="quote">Thanks for the help guys. Anyone have one laying around that they want to get rid of?
Modified by cougar289 at 6:03 PM 10/15/2008</TD></TR></TABLE>
you don't really need it, especially in Florida - the FICV is only there to boost the idle slightly when the air temperature is really cold, -10C or 14F - other than that, it does nothing - just block off the vacuum ports and leave it - if you want to run it, you will need to add wiring to the ECU
yea what he said, its not really necessary.
The fast idle control solenoid valve, mounted on the right side of the throttle body, is used to increase the air flow rate for fast idling at extremely low ambient temperatures.
OPERATING CONDITIONS:
The Fast Idle Control Solenoid Valve is turned on when the Coolant Temperature is Below 14°F (-10°C) AND Engine Speed is Below 1,800 rpm.
eruktion
Jul 14, 2009 05:58 PM
bigsnorlax
Jun 12, 2009 05:06 PM
_Endless_
Dec 16, 2004 10:16 PM
