90k maintenance price
Old Oct 15, 2008 | 12:55 PM
brandobot89's Avatar
Default 90k maintenance price
i got quoted for $900 for spark plugs, cap, rotor, wire set, fuel filter, pcv valve, timing belt, balancer, alternater, ac and all other belts. crankshield? or was it crankshaft? camseal, valve seals..valve cover gaskets, and some all the gasket kits from honda. is that a fair price?
what else should i get?
Old Oct 15, 2008 | 03:28 PM
Kronn 98SH's Avatar
Default Re: 90k maintenance price (brandobot89)
what parts are actually being replaced and what parts are merely being inspected? what vehicle do you have? If ALL of those parts are being replaced, it might be close to a fair deal.
Old Oct 15, 2008 | 04:07 PM
Default Re: 90k maintenance price (Kronn 98SH)
Spark plugs, wires, cap, rotor, fuel filter, pcv valve, timing belt/balancer and related, alternator, ac and other belts, water pump, cranksheild?, cam seals, valve seals, all gaskets and fluids are being replaced.
it's a 2000 prelude base model.
Old Oct 15, 2008 | 04:22 PM
Kronn 98SH's Avatar
If you don't plan on doing any of that work yourself, I say go for it. Prices around here are like this:
Timing Belt + Water Pump: Parts + Labor ~ $1200
Fuel Filter ~ $150
Plugs, Wires, Cap, Rotor ~ $200
Radiator flush ~ $100
Transmission flush ~ $100
Total ~ $1750
Old Oct 15, 2008 | 04:36 PM
Thanks, im gonna do it next week!
Old Oct 15, 2008 | 04:50 PM
2000h22a's Avatar
make sure its a reputable shop, and try to use oem parts...
Old Oct 15, 2008 | 04:51 PM
Kronn 98SH's Avatar
Of course, I recommend you check the place out first. See what other customers & shops say about them. See what brands of parts they intend to use. Etc.
When I take my car in to have work done because I don't want to deal with the frustration of it, I always test the mechanics by asking them some Honda-specific questions. If they can't answer them, I leave.
Old Oct 15, 2008 | 07:06 PM
the owner of the shop is a family friend. he will be doing all the work himself. It is all oem honda parts. he worked for honda for a number of years..
Old Oct 15, 2008 | 07:08 PM
vinuneuro's Avatar
That's a pretty reasonable price if he's changing valve seals too.
pho iz good
15
Jun 6, 2017 12:58 PM
easyFOsheezy
Sep 11, 2010 03:10 PM
LazJDM
Apr 17, 2006 05:00 PM
jeremy.
Feb 8, 2005 10:42 AM
nek0
Sep 26, 2002 10:46 PM
