Suspension & Brakes Theory, alignment, spring rates....
itr spec or gsr spec?
Old Oct 15, 2008 | 10:42 AM
b18c1vtecdc2's Avatar
Default itr spec or gsr spec?
Currently i have jdm itr shocks & springs, LCAs,sway bar and i want to upgrade to GC & koni yellows should i get the itr spec or gsr spec? i think there different not positive please help me out thanks in advance.
Old Oct 15, 2008 | 05:13 PM
CubanoRockr's Avatar
Default Re: itr spec or gsr spec? (b18c1vtecdc2)
i would recommend to go with the ITR set up for the rear lower control arm, which are different from the gsr, either than the rear lca's the spring rate should work with your current set up of sway bars.
Old Oct 15, 2008 | 06:01 PM
Targa250R's Avatar
be professional
Since you're already using the ITR rear lower control arms, you're going to need to use ITR-specific rear dampers.
fuguman
Aug 27, 2002 02:04 PM
JM Performance
May 13, 2002 04:31 PM
NAB
Apr 7, 2002 11:34 PM
Beyond Imagination
Mar 15, 2002 04:26 AM
98CivicDX
Feb 15, 2002 11:10 AM
