Honda S2000 Honda S2000
Misfire Problem (CEL)
Old Oct 15, 2008 | 10:18 AM
GSR-Tetsuo's Avatar
Default Misfire Problem (CEL)
So last week i threw a CEL.
( DOH i just searched and found a similar thread, but it didnt help me much ) (edit)
I scanned my codes and threw 6 different ones.
P0300
P0301
P0302
P0303
P0304
and
P01399 ( i think if i remember right )
All had to do with misfires and random misfires in all cylinders.
I changed spark plugs ( they were the OEM ones and had 70k miles on them)
reset my codes and drove home.
THe next day i threw a CEL again.
This time only one code, P0302 ( misfire detected in cylinder 2 )
Any ideas on what this could be?
Coil Pack?
Injector?
Crank?
Old Oct 15, 2008 | 10:51 AM
TypeR324's Avatar
Default Re: Misfire Problem (GSR-Tetsuo)
I had the same problem and it was my coil pack, I would start there.
Old Oct 15, 2008 | 11:03 AM
White Smoke's Avatar
i my honda
Global Mod
Reset and see if it happens again in # 2. Do that a few times and if #2 keeps coming up try switching the #2 coil pack with another cylinder and see what happens from there. If it follows the coil pack you found your problem.
Old Oct 15, 2008 | 11:08 AM
Duane_in_Japan's Avatar
Default Re: Misfire Problem (White Smoke)
Very good idea but you would have to do the test several times and clear the code several times since initially you had all cylinders misfiring, this could also be the way you drive and you may have gone lean on heavy accel, which means a fuel system and fuel injector servicing is due so drive normal till you get it figured out.
Old Oct 15, 2008 | 04:17 PM
GSR-Tetsuo's Avatar
Default Re: Misfire Problem (Duane_in_Japan)
Found the problem.
My Berk Test pipe ( with the "CEL FIX" built in) was having my 02 sensor too far into the exhaust stream. The 02 sensor was reading the exhaust as "too rich" and leaned out the amount of fuel being put into the engine.
I bought a longer 02 cel fix, hopefully that will work.
TypeR324
Honda S2000
May 8, 2009 01:30 PM
TypeR324
Honda S2000
17
Apr 15, 2009 09:42 AM
98CivHx
Sep 11, 2006 11:31 AM
DSM_DC5
Aug 3, 2004 05:33 PM
slackeR1366
May 6, 2002 12:48 PM
