Blue Smoke out of Exhaust
Old Oct 14, 2008 | 11:12 PM
drave's Avatar
Default Blue Smoke out of Exhaust
Hi there,
I've got a JDM B16A swap in a 99 EK hatch.
I'm getting a blue puff out of the exhaust, but only when I shift. Mods are simply an intake, no cat, apexi n1 muffler, GSR header. It's not oil, the level hasn't dropped at all. From what I've heard, blue smoke is excess fuel? So is basically is all I need a tune, because I'm running really rich? Or would the lack of cat cause this?
Thanks.
Old Oct 14, 2008 | 11:15 PM
hmtcrxsir's Avatar
Default Re: Blue Smoke out of Exhaust (drave)
youre burning oil. Sounds like your piston rings is going bad. I think if you running rich its more black than blue
Old Oct 15, 2008 | 05:52 AM
P12 EG6's Avatar
Default Re: Blue Smoke out of Exhaust (hmtcrxsir)
yes, blue smoke is a sign that your rings are going down hill, if it only does it at shifting thats means there not horrible but its only gonna get worse... time for a rebuild!
Old Oct 15, 2008 | 09:17 AM
drave's Avatar
Default Re: Blue Smoke out of Exhaust (P12 EG6)
If it were oil, my level would go down, no? And why would it start burning oil at 75xxxkm?
Old Oct 15, 2008 | 09:31 AM
shifty35's Avatar
If it only puffs when you shift, chances are it's valve seals. A little bit easier / cheaper to replace than the rings, but you may as well do those too while you have it apart.
ERKK
Apr 9, 2010 04:00 AM
B18cFreak
Apr 17, 2007 02:04 PM
dexGSR99
Feb 6, 2006 04:27 PM
T25So
Sep 8, 2004 11:39 AM
Cyber ITR
Jan 7, 2002 05:10 PM
