ASR subframe brace and sway bar on ef?
Old Oct 14, 2008 | 11:06 PM
EFstyle's Avatar
Default ASR subframe brace and sway bar on ef?
I know its posible because I've seen it in person but just never got a chance to ask the guy what he had to do to make it work... Anybody on H-T ever done this? If so, any light you can put on the subject would be great! thanks
Old Oct 14, 2008 | 11:15 PM
pandarex's Avatar
Default Re: ASR subframe brace and sway bar on ef? (EFstyle)
i know the down side being you cant run a full exhaust, but thats a good reason to buy a red shift exhaust. the other being the price. redshift wrote up on it.
http://www.redshiftmotorsports...e.htm
Old Oct 15, 2008 | 04:05 PM
EFstyle's Avatar
Default Re: ASR subframe brace and sway bar on ef? (pandarex)
id be going under axel anyways i have 15x7.5's with a 0 offset so the car is most deffinitly not slammed by any meens... ill have room for under axel
Old Oct 15, 2008 | 04:18 PM
4DRmafia's Avatar
So, you're saying we can use the eg sub frame brace?
Old Oct 15, 2008 | 04:29 PM
EFstyle's Avatar
Default Re: (4DRmafia)
well i was planning on the st rear sway bar but people always talk about the brackets where the bar mounts to the shock bolt on the LCA and how they spin unless welded on.... i guess i dont fully understand. i have PIC Selects so there will be no welding obviously... anybody have pics of a st bar and where the bracket spins and why?
Old Oct 15, 2008 | 04:44 PM
4DRmafia's Avatar
on the lca you mean?
Old Oct 15, 2008 | 04:46 PM
EFstyle's Avatar
im not totally sure... from what ive read most people weld the bracket for the endlinks right to the shock fork...
Old Oct 15, 2008 | 04:49 PM
4DRmafia's Avatar
wait, you talking about the front or the rear? You just said shock fork and that making me thinking you're talking about the front.
Old Oct 15, 2008 | 05:38 PM
Tyson's Avatar
ask PRkiller
Old Oct 15, 2008 | 05:53 PM
EFstyle's Avatar
no i meen the rear... what i ment by "shock fork" was just the bottom part of the rear shock that fits over the rear lca... my bad for the confusion
Old Oct 15, 2008 | 07:53 PM
4DRmafia's Avatar
i know my rear lca is a om si arm, which has a mount point for it and it doesnt turn or anything
Old Oct 16, 2008 | 08:06 AM
gringo7718's Avatar
here are some pics of the brackets for the ST sway bar
http://www.gearz.org/Fun/Proje...r.htm
GameBoyeas
Apr 20, 2018 10:56 AM
88 EF Hatch
20
May 3, 2009 01:12 PM
Super79Dave
14
Nov 26, 2008 08:45 PM
thehatchninja
Oct 11, 2006 01:29 PM
