98 Accord LX Coupe - driver & passenger power windows and mirror controls stop working simultaneousl
I have a 98 Accord LX coupe manual and the driver & passenger windows, and power mirrors stop working at the same time.
When I try try to open or close the driver side window I hear a "click" sound from the switch (which I normally hear when I either pull the switch up when the window is already up or push the switch down when the window is already down), but the window doesn't do anything, and the passenger window switch (both driver and passenger side) make no noise and don't do anything.
Also, the power mirror controls don't work either.
It all started earlier today...
I have been having a problem starting my car for quite some time, which has just been getting worst (Today being the worst). When I try starting the car, I hear a single "click" from the starter and that's it. This morning I had to try "starting" the car over 15 times, each time getting only a "click", until it eventually turned on.
I think it's the starter going (really) bad.
This is when I first noticed this problem with the windows. And mirror controls, which I think is related because the window switches are right next to the mirror controls.
Could my constant starting attempts have shorted something out?
I have checked the 2 driver and passenger power window fuses on the passenger side, the power window motor fuse and the back up, ACC fuse in the engine compartment.
Electrical things that ARE confirmed to be working are the: door lock switches, clock, a/c controls, radio, cigarette lighter outlet, dome light, map lights, courtesy door lights, visor lights, cruise, gauges, headlights, taillights and hazards. Which is pretty much everything else.
Any help on this problem would be greatly appreciated...
This morning after about 20 minutes of driving both windows started working! (MAGIC!!
I was concerned that the windows might stop working again (and be get stuck while open) so I quickly rolled them back up. And as soon as I rolled them up, (less than a minute went by) I tried opening the windows again, but this time NOTHING!!
I kept testing the windows throughout the rest of my driving today. But that was the last time my windows opened.
I still have no idea what's wrong or why the windows randomly started working.
anybody?????
).I was concerned that the windows might stop working again (and be get stuck while open) so I quickly rolled them back up. And as soon as I rolled them up, (less than a minute went by) I tried opening the windows again, but this time NOTHING!!
anybody?????
i would be looking at the harness between the door and A pillar sounds like a broken or frayed wire or so
I want to say that there is power getting to the switch because I can hear the very subtle "click" (coming from the switch) when you try to open or close the window.
If something is wrong with the harness on the driver side, would it also be effecting the passenger side window switch too?
yes .the click you are hearing i would imagine is the window switch trying to work but if the harness has a break then the voltage would not complete thru the window circuit and partial voltage is the result of the clicking. also check the connectors at the door pillar for a loose pin fit's
Does the harness for the window switches on the driver side directly effect the window switch on the passenger side?
im getting this type of problem but for my 01 fourdoor and it stopped working right after i pumped gas. but the thing is all 4 windows and switches dont make a clicking sound or even roll up or down which is really scaring me. would there be a fix to this?
uhm there is a way to reset the multiplex. this is a common problem after power has been disrupted (IE changing a battery). set the intermittent wiper ring to the middle position and then turn the car on for 10 seconds and then turn off.
stuff should start working again.
Yours sounds like a fuse has blown...check those out and replace any blown ones. you can buy auto fuses at walmart...
yes. do this. If it's not an intermittent power issue, then most likely it's a problem with the multiplex system. I would say that since it is so easy to do, you should try that first.
did anyone mention this yet?
Please help I have the same issue except my driver's side window operates fine. It's my passenger window which goes down extremely slow and when I try to raise it, it doesn't go all the way up. Starts making a continous click, click, click and stays about 2" open. I also have a 98 Accord Coupe LX.
Hawaii Da9
Jan 16, 2012 06:19 AM
