peicing toghther a turbo kit for ep3, engine managment question
hows it going, im currently building a turbo kit for my ep3, i dont have a lot of money so im trying to stay away from the greddy type kits, my question is, what is a good engine management system for running forced induction other then the kpro, i looked at the apexi neo, also what size injectors would you think for a 7 pound setup, and last has any one else done this, what did you use for a turbo, thanks anything will help
An apexi neo is not going to allow you to properly tune your motor.
If you skimp out on your engine management & tuning you will end up with a useless motor.
Hondata K-pro
Hondata K-pro
do not skimp out on engine management ..... K-pro is the way to go we have a very healthy ep3 on kpro and its a beast on 10lbs stock motor
As everyone else has said, K-Pro is the only way to go with your setup. Also, your injector decision will be made once you determine an approximate (realistic) power goal. Setting your goal in terms of PSI doesn't tell us anything...
big-cat
14
Feb 22, 2006 01:33 PM
