Question about alignment after drop.
Im about to drop my integra 1.5 inches with the prokit. I know I need an alignment, but is the shop going to align the car like any other time or are there new specifications to abide by?
Instruct them to ignore the camber and to set the toe to dead center of the factory tolerance range at all four corners. Ask for before and after printouts, and post the specs here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Instruct them to ignore the camber and to set the toe to dead center of the factory tolerance range at all four corners. Ask for before and after printouts, and post the specs here.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Instruct them to ignore the camber and to set the toe to dead center of the factory tolerance range at all four corners. Ask for before and after printouts, and post the specs here.</TD></TR></TABLE>Good info. Exactly what i was looking for. Thanks
Wait, what exactly are these printouts? Will they know what i mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR »</TD></TR><TR><TD CLASS="quote">Wait, what exactly are these printouts? Will they know what i mean?</TD></TR></TABLE>
Unless they're doing the alignment in a pit with a tape measure, string, toe plates, and a trig calculator, they'll know what you mean.
You should probably call beforehand to ask the shop about their policy for cars with altered ride heights. Also, you may want to take some tools with you to remove the front bumper if necessary. Depending on the ride height, any lip attachments, and the type of alignment rack, the bumper cover may need to be removed for the head sensors to have a line of sight.
You should probably call beforehand to ask the shop about their policy for cars with altered ride heights. Also, you may want to take some tools with you to remove the front bumper if necessary. Depending on the ride height, any lip attachments, and the type of alignment rack, the bumper cover may need to be removed for the head sensors to have a line of sight.</TD></TR></TABLE>
not with pro kits.
not with pro kits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">not with pro kits.</TD></TR></TABLE>
Somehow the fact that he's installing Pro Kits completely escaped me.
Forget I said that.
Forget I said that.
CivicSiRacer
May 12, 2003 03:18 AM
