EF LS SWAP, GOT 2 CODES..need help
ok so i got a ls swap in my ef. now i also have 2 ecus.
one is a pr4 (obd0 LS) ecu re-manufactured, and the other is the stock si ecu(non vtec)
on the SI ecu i get one code. and thats a one for the 02 sensor.(with zc injectors)
and on the LS ecu i get the 1, and a 43. i ALSO have zc injectors supplying fuel.
now the stock motor, and the SI ecu on the LS only had the (1) so im assuming its NOT the pump, or filter.
i think its the injectors or the o2 sensor(for the 43)
(and i know 1 is the o2 sensor)
can some one point me in the right direction for the 43
THANKS
THANKS
Without looking I am pretty sure that the code 43 is fuel supply system code. I got this code myself on my LS swapped rex. When I went to get my exhaust fixed I noticed that I had a hole in my header right in front of my o2 port. I had the exhaust guy weld it up untill I can get me a new header and since then the code has been gone! Hope this helps.
so with your current setup is it just your o2 code comin up or your fuel codes still... if fuel codes grab up some stock ls injectors if everything else is stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 »</TD></TR><TR><TD CLASS="quote">Without looking I am pretty sure that the code 43 is fuel supply system code. I got this code myself on my LS swapped rex. When I went to get my exhaust fixed I noticed that I had a hole in my header right in front of my o2 port. I had the exhaust guy weld it up untill I can get me a new header and since then the code has been gone! Hope this helps.</TD></TR></TABLE>
ya well the header on the ls is ok and so was the sohc one aswell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmed3 »</TD></TR><TR><TD CLASS="quote">so with your current setup is it just your o2 code comin up or your fuel codes still... if fuel codes grab up some stock ls injectors if everything else is stock</TD></TR></TABLE>
will replace o2 sensor, and swoop on these at the junkyard
whatdoyoumean
May 9, 2012 11:43 PM
freak86
Aug 10, 2006 08:49 AM
anyone else
