obd0 B16a1 into a classic mini...wiring gameplan help needed.
Old Oct 14, 2008 | 11:43 AM
sachilles's Avatar
Default obd0 B16a1 into a classic mini...wiring gameplan help needed.
So long story short, I have 1961 morris mini.
I'm putting in a b16a1 into the car.
Parts I have
b16 motor, and engine side harness obd0
socketed pr3 ecu that worked with the motor previously.
I also have:
a complete engine harness from a 94 civic(non-vtec).
a chassis side wiring harness for a 94 civic(non-vtec).
instrument cluster from the 94 civic
P30 ecu obd1
s80 hydraulic transmission(with lsd) with speed sensor and reverse sensor.
header with only one port for o2 sensor.
I was told originally it made more sense to go obd1, as there are more tuning options.
However, from the cost side, it looks like I'll need a obd1 distributor($200+), a 4 wire o2 sensor($60), different fuel injectors($275+). It still looks like I'd need more wiring harnesses built or customized.
Because I'm a honda newb, I'm hoping you can help develop a gameplan that makes sense.
Why do I want to go obd1, and what more do I need for parts/harnesses?
What if I wanted to go obd0, would I be screwing myself in the long run? What would I need to get the car running on obd0?
The car is caged and intended as a hobby racer. Even the least powerful version of software running the b16 will be a huge improvement over the old motor. However, you can never have too much power.
I'm leaning towards obd0 even though it may not be the wisest choice for tuning in the future.
Thanks for your help
Old Oct 14, 2008 | 05:54 PM
LA_HONDAS's Avatar
Default Re: obd0 B16a1 into a classic mini...wiring gameplan help needed. (sachilles)
check this out https://honda-tech.com/zerothread/2396244
Old Oct 26, 2008 | 02:43 PM
Liquidgsr's Avatar
Default Re: obd0 B16a1 into a classic mini...wiring gameplan help needed. (LA_HONDAS)
My cousin did this except a OBD1 B16 into his 1969 mini.
jdmboi3278
Engine Management and Tuning
Jan 28, 2009 11:17 PM
xiong1001
Jul 13, 2008 02:13 PM
lazyboy
Oct 8, 2005 06:49 AM
Loccster
Sep 17, 2004 04:09 PM
Mefain
Feb 16, 2004 09:39 PM
