Pulling engine from 5th gen- ahhh!!
a load leveler would be nice
we always have to put it back down, move the chain, up again, blah blah blah
vig, you keeping the a/c in tact or can you let the pressure out?
If so, taking that line off the evap coil near the firewall is easy enough. If not.....have fun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">Tilt the engine. It's pretty easy to do if you have a load leveler on the hoist.</TD></TR></TABLE>
One person tilting the engine and lifting it, the other person leaning back on the pass. side while holding on to the AC line...
x2
A leveler is your best friend when no one else is around to help.
x2
No load leveler, but there's two of us getting it out. We'll have to mess around with it I guess. There's surprising little room on either side, good thing I already had the crank pulley off.
And yes Matt, I want to keep AC.
I found the AC line to be remarkably durable
edit: And I did it with no load leveler, just with an engine hung a little sideways. I think I was partially standing on the transmission at one point, though...
Thanks guys. We ended up getting it out pretty easily last night. Just adjusted the links on the chain so that the trans side would naturally drop down as the hoist was raised.
That AC line looks even more ridiculous in the bay without the engine there. Just can't believe Honda couldn't place it more conspicuously.
Thanks.
Thanks.
