Valves tapping bad on 96 Accord V6
Old Oct 13, 2008 | 07:04 PM
SneezinCD5's Avatar
Default Valves tapping bad on 96 Accord V6
My GF has owned her 96 Accord V6 for about 5 years now. I have done all of the maintence on it since we have had it. The valves tap really bad. She has around 175K I know they are hydraulic and fix themselves after it warms up. They didn't tap when we first got the car (78K miles) but when they started to, it would go away after a few minutes. About 2 weeks ago, I noticed that the noise would come and go even after it warmed up. When I would change the oil, it would help alot but just wondering why the valves keep taping even when its warm.
Old Oct 13, 2008 | 07:19 PM
YeuEmMaiMai's Avatar
Default Re: Valves tapping bad on 96 Accord V6 (SneezinCD5)
uhm when was the timing belt done?
first valve adjustment is either 60K (severe) or 120K miles (normal)
Old Oct 13, 2008 | 07:25 PM
oblivion2kx's Avatar
Have the valves adjusted, and check for oil in the spark plug tubing. If you see oil, then you probably should change your valve gasket. If you dont want to spend the 100$ to get the adjusted, just use heavier oil.
Old Oct 13, 2008 | 07:51 PM
nus_dogg's Avatar
yup, needs a valve adjustment. since its a v6, i'd rather have the pro do this one.
Old Oct 13, 2008 | 08:30 PM
SneezinCD5's Avatar
Default Re: (nus_dogg)
You cannot adjust the valves on the C27 engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nus_dogg &raquo;</TD></TR><TR><TD CLASS="quote">yup, needs a valve adjustment. since its a v6, i'd rather have the pro do this one.</TD></TR></TABLE>
You think im a NOOB?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oblivion2kx &raquo;</TD></TR><TR><TD CLASS="quote">Have the valves adjusted, and check for oil in the spark plug tubing. If you see oil, then you probably should change your valve gasket. If you dont want to spend the 100$ to get the adjusted, just use heavier oil.
Just changed the plugs about 2 months ago, no traces of oil were found. I am using 10W40 right now. Don't wanna run anything much thicker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">uhm when was the timing belt done?
first valve adjustment is either 60K (severe) or 120K miles (normal)</TD></TR></TABLE>
Timing belt is fine. I changed it at 100K. I inspected the belt when I did a full tune-up on it. No cracks or wear and had the correct tension.
Old Oct 13, 2008 | 09:19 PM
dtapia's Avatar
Default Re: (SneezinCD5)
the most common problem and repairs made to the early v6 was installing new lifters. but make sure you soak the new one's in oil for 12 hours or more. it will make a huge difference if not it will take some time to build up the oil in the lifters.
Old Oct 13, 2008 | 09:33 PM
SneezinCD5's Avatar
Default Re: (dtapia)
Thanks, your the only one who knows that you can't adjust them. I will look into getting new lifters but not looking foward to messing with it since there is NO ROOM in the bay
Old Oct 13, 2008 | 09:35 PM
dtapia's Avatar
it's not that bad to do.
Old Oct 14, 2008 | 04:09 AM
GhostAccord's Avatar
I have never worked on a V6 Accord. Could someone tell me why the exhaust side on the V6 has tappet adjusting screws. Are they only used in the initial cam install and then after that they self adjust? My manual doesn't go into great detail on how the system works. I'm just going buy the step-by-step for the cam install.
I see the hydraulic valve lash adjusters/lifters for the intake side. But nothing that looks self adjusting on the exhaust side. I mean it's f#@ked that you just tighten them up until they touch the valve. Then give them another 1 1/8th turn tighten them and your done. Sounds like your putting on an oil filter not setting a valve adjustment. Why have "adjusting screws" if there are no adjustments to be made or clearance values?
Old Oct 14, 2008 | 05:45 AM
dtapia's Avatar
Default Re: (GhostAccord)
this is a weird system when i went to training years back on it i was stumped for a min but then the instructor made me see the way. it was a very short lived motor on the accord but it was used on the first gen legends.
the adjuster on the exhaust side is to preload on the rocker arm and the push rod it's the way that system was put to work. it don't make any sense why the domestic auto's us a similar system and no adjusting involved.
Old Oct 14, 2008 | 06:10 AM
SneezinCD5's Avatar
When this motor takes a crap, am I able to swap another V6 in (J30)?
Old Oct 14, 2008 | 06:44 PM
CL SLeePeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 &raquo;</TD></TR><TR><TD CLASS="quote">When this motor takes a crap, am I able to swap another V6 in (J30)?</TD></TR></TABLE>
It's feasible.. The 5th gen v6 shares the same front and side mounts as the 1st gen 3.0cL.
Old Oct 14, 2008 | 06:52 PM
OHC engines have lifters? that's push rod stuff there
Old Oct 14, 2008 | 07:12 PM
dtapia's Avatar
Default Re: (YeuEmMaiMai)
Old Oct 14, 2008 | 07:19 PM
SneezinCD5's Avatar
Default Re: (CL SLeePeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CL SLeePeR &raquo;</TD></TR><TR><TD CLASS="quote">
It's feasible.. The 5th gen v6 shares the same front and side mounts as the 1st gen 3.0cL. </TD></TR></TABLE>
So thats the only swap that would be able to drop in? Whats the engine code on that motor?
Old Oct 14, 2008 | 07:27 PM
1st gen CL used the J30 for the V6 variety.
Old Oct 14, 2008 | 07:50 PM
SneezinCD5's Avatar
So would the J30 out of the 98+ Accord fit?
Old Oct 14, 2008 | 08:39 PM
CL SLeePeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 &raquo;</TD></TR><TR><TD CLASS="quote">So would the J30 out of the 98+ Accord fit?</TD></TR></TABLE>
Yes.
Old Nov 6, 2011 | 05:36 AM
OUBob's Avatar
Searching for cam timing marks on here and found this dead thread and lol'd.
C27: Valves ARE adjustable. Looking at them now. HAS lifters and pushrods and is an OHC engine. Just put the head back together a half hour ago, and looking at it now.
Old Jul 17, 2017 | 05:01 PM
Chad Seifert's Avatar
Oil won't get into the spark plug tubes on this engine. On the four cylinder, oil gets into the spark plug tubes because of bad rocker orings. Don't give bad advice. If you don't know what you are talking about, please don't comment.
rondogg779
Oct 28, 2019 11:19 PM
tommyleeruiz
Jul 29, 2008 06:57 PM
SIMATIC
Jul 25, 2003 01:15 PM
Lowez
May 19, 2002 04:00 PM
