H22 DC Integra power steering
So I have seen a couple different things online about which power steering line to use for this motor. I have seem something about 96-00 civic and also 97+ prelude line. Which one is it, or do they both work? If anyone knows this answer or has actually done it, it would be greatly appreciated, thanks!
ok, so I skipped over this somehow. Just for reference the 97+ power steering line and pump will work. Here is the reference http://www.jdmshit.com/hcp/EGfitment/
If you are swapping an EG, you can also use a die grinder with a 1/2" rounded end bit to dig a groove in the bracket, then tweak the line a little to fit
This may work on other models as well, good luck with it as I haven't tried it on anything but my own car
suncoastcustoms
Apr 28, 2004 04:26 PM
KStuned
Sep 11, 2003 11:48 AM
