2002 Accord Power Window problem
Front left (driver) window was not working. I thought I had checked the fuse already. I took apart the door and was following the Haynes manual, checking the switch for voltage. I must have done something to the circuit, though, because now the driver door cannot control the other windows. The clock is blank. And the keychain remote does not work. In desperation, I checked fuses and the driver's window was blown. Ugh.
Haynes manual mentions a circuit breaker on the system, but does not say where it is. Also, windows work fine from their doors (as long as the On/Off switch on the driver's door is set right).
Check engire light is a steady yellow.
Please help!
Thanks.
Please help!
Thanks.
chris4x4
13
May 8, 2011 10:39 AM
tormont
Dec 1, 2010 08:44 PM
