HOW TO CHANGE BRAKE BOOSTER AND MASTER CYLINDER
Old Oct 13, 2008 | 12:34 PM
ilvi3tkidxx's Avatar
Default HOW TO CHANGE BRAKE BOOSTER AND MASTER CYLINDER
planning on changing master cylinder and etc.. i think it took a **** soo trying to c how u guys did it =p
Old Oct 13, 2008 | 12:37 PM
vietnamezerice's Avatar
Default Re: HOW TO CHANGE BRAKE BOOSTER AND MASTER CYLINDER (ilvi3tkidxx)
for the master cyl... take the two brake lines off and then then the two nuts that hold the master cyl and that's it... for the brake booster, it's held on by four nuts
Old Oct 13, 2008 | 12:40 PM
ok thnx.. is there any bleeding involved?.....o yea my brake pedal sinks very slowly.. so shud i start wit changing the booster first? and then master cylinder?
Old Oct 13, 2008 | 12:41 PM
95LSt's Avatar
with relevance to the future, picking up a haynes manual from advance/autozone would be a good idea!
Old Oct 13, 2008 | 12:46 PM
95LSt's Avatar
yeah you have to bleed the mc
Old Oct 13, 2008 | 12:55 PM
well imma try bleedining and flushing everything out AGAIN... and if not... change the booster... and if that STILLL doesnt work then ill do the master cylinder... and if that stilll doesnt work then.. im f'ed...i have no leaks either =/
Old Oct 13, 2008 | 04:22 PM
danthemang3's Avatar
i would do the mc first. brake boosters are crazy expensive and the mc is the usual culprit.
Old Oct 14, 2008 | 09:30 PM
Default Re: HOW TO CHANGE BRAKE BOOSTER AND MASTER CYLINDER (danthemang3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danthemang3 &raquo;</TD></TR><TR><TD CLASS="quote">i would do the mc first. brake boosters are crazy expensive and the mc is the usual culprit.</TD></TR></TABLE>
a sinking pedal usually indicates a bad seal in the MC
Old Oct 14, 2008 | 09:47 PM
Circusraven's Avatar
Default Re: HOW TO CHANGE BRAKE BOOSTER AND MASTER CYLINDER (vietnamezerice)
Buy a FLARED wrench for the brake lines! 12mm. Or else there's a good change you'll strip the heads, then you'll really be screwed
Old Oct 15, 2008 | 09:45 AM
ok.. thnx guys
Old Oct 15, 2008 | 09:46 AM
well im about to pick up a booster and master cylinder from my friends integra cuz he had no problems with his breaks and hes parting it out hopefully all goes well
Old Oct 15, 2008 | 09:57 PM
remember, don't change you booster first, change the master... and if that fails then the booster but I highly doubt it's the booster that's messed up
Old Oct 16, 2008 | 04:07 PM
ok cool thnx .. dam alotta work.. wen i take out the master and put the other one in.. i have to rebleed the brakes all over agen?
Old Oct 16, 2008 | 06:51 PM
bleed the master first and then each wheel
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
mattmw88
Mar 31, 2008 06:08 PM
integra123
Aug 8, 2006 05:52 PM
