wierd noise
Old Oct 13, 2008 | 11:25 AM
teg_dc2's Avatar
Default wierd noise
i got this wierd noise when im accelerating its like a humming noise and i usually hear it when im on the freeway, it seems to get louder as i accelerate, anyone know what this might be?? it hums and is like a whinning sound, gets loud, then goes away in a pattern.
Modified by teg_dc2 at 1:22 PM 10/13/2008
Old Oct 13, 2008 | 11:51 AM
teg_dc2's Avatar
Default Re: wierd noise (teg_dc2)
anyone??
Old Oct 13, 2008 | 12:21 PM
teg_dc2's Avatar
bump!
Old Oct 13, 2008 | 12:36 PM
weavertime1's Avatar
This humming could be a variety of things...Cupped tires can make this type of noise, as can bad wheel bearings, or even a bad transmission bearing.
Old Oct 13, 2008 | 12:39 PM
Adankid's Avatar
do you have any aftermarket parts?
Old Oct 14, 2008 | 07:36 PM
teg_dc2's Avatar
Default Re: (Adankid)
no not in the suspension.
Old Oct 14, 2008 | 08:32 PM
vietnamezerice's Avatar
Default Re: (teg_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">This humming could be a variety of things...Cupped tires can make this type of noise, as can bad wheel bearings, or even a bad transmission bearing.</TD></TR></TABLE>
check all those and post back
Old Oct 15, 2008 | 11:29 AM
teg_dc2's Avatar
Default Re: (vietnamezerice)
ok will do!
Old Oct 15, 2008 | 11:32 AM
sh4mr0ck's Avatar
My car makes noise when I accelerate, too... turns out its just the engine reving j/k, I just wanted to be a dick
It could be multiple things... is everything balanced correctly in your unsprung weight?
Old Oct 15, 2008 | 11:45 AM
teg_dc2's Avatar
Default Re: (sh4mr0ck)
do you think it could be the springs that came with the car, when i bought the car they said it had been lowered but when i checked the springs they were stock springs, so i guess the previous owner had cut the springs or heated them, is this what might be causing the noise??
Old Oct 15, 2008 | 11:58 AM
Springs should not cause a humming noise, unless they are somehow hitting the tire as it turns or something...you gotta love backyard mechanics who lower cars by cutting the springs...good luck in fining your problem...and by unsprung weight he meant wheels/tires, braking system, and cv axles.
Old Oct 15, 2008 | 12:01 PM
sh4mr0ck's Avatar
It could be in conjunction witht eh springs. The humming sounds more like the car is slightly out of alignment... does it shake or rattle at all at higher speeds?
If the car is lowered by cutting, then most likely it is out of alignment because they probably didn't get it all straight after the drop... that would cause a humming sound at higher speeds...
Also, check your tires, some tires make the humming because of the composition of them... hard/soft.
Old Oct 15, 2008 | 12:03 PM
teg_dc2's Avatar
i havent got an alignment yet so ive probably going to get one soon, and also new coilovers to replace the cut springs. hopefully this will solve the noise problem.
Old Oct 15, 2008 | 12:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">It could be in conjunction witht eh springs. The humming sounds more like the car is slightly out of alignment... does it shake or rattle at all at higher speeds?
Also, check your tires, some tires make the humming because of the composition of them... hard/soft.</TD></TR></TABLE>
Alignment won't make a car hum...it will however make the tires wear unevenly, thus causing a hum...if you decide to get coilovers and lower the car more than 1.5 inches or so, at least invest in a front camber kit so that your camber can be brought back in to factory specs, as the EG/DC chassis does not have any camber adjustments from the factory. The rear will have a slight amount of negative camber, but very rarely do I see rear camber issues on lowered hondas...also JFTR, toe can be a major contributor in overall tire wear, but fortunately the EG/DC chassis does have factory toe adjustment which will be taken care of during a simple thrust angle alignment. Good luck!
Old Oct 15, 2008 | 01:07 PM
teg_dc2's Avatar
Default Re: (weavertime1)
yeah i was wondering that it might be the alignment issue and tires wearing unevenly, making the noise so yeah ill get the alignment done and then the coilovers with the front camber kit, this should solve everything.
Old Oct 16, 2008 | 04:40 AM
Do you have another set of rims and tires to put on to test the theory first?
Old Oct 16, 2008 | 09:33 PM
teg_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have another set of rims and tires to put on to test the theory first?</TD></TR></TABLE>
no i dont.
Old Oct 16, 2008 | 09:37 PM
my car makes a funny rattling noise when I accelerate too
Tony Cameron
Dec 11, 2013 06:31 AM
JennAMP
Transmission & Drivetrain
Nov 19, 2012 09:02 AM
DB8_LSVTEC
Jun 1, 2008 06:26 PM
ednyboo
Jun 5, 2007 08:55 PM
DC5_R
Jun 30, 2003 03:35 AM
