USDM '90 Civic => JDM EF9
Who knows exactly what front bulkhead is used for the conversion to EF9 - minus the t-bar?
I’ve heard there’s a difference and you need to use the ’89 headlamp bucket for the EF9 headlamps. So this leads me to believe there might be a difference for the front bulkhead between the two years…
Yes I’ve searched and no the info I’m looking for hasn’t showed up yet…
So, I'll just answer my own question...
You may use either.
Why? Well if you look at the part numbers for the two years they are the same - not the assembly, but the headlamp area. So I'll assume that since they're the same - and you only need to change the t-bar then - one would be safe using either for the EF9 front end...
You may use either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0041 »</TD></TR><TR><TD CLASS="quote">So, I'll just answer my own question...
You may use either.
I've heard of people doing this, but you have to be crazy precise when lining her up
You may use either.
you can do it with out the t-bar, but you just need to play around with the fitment of the hood /head light and front bumper. i done my with out the fender and the t bar look ok but not perfect line up but look damm good.
As of right now the car doesn't have a front bulkhead on it so it's not going to be that bad...
The car was in an accident and needs the front replaced; so without further ado here we go.
andrew714
Apr 13, 2006 02:12 AM
Double Agent
Mar 29, 2006 09:40 AM
Problemo
Mar 10, 2006 12:06 AM
