ASR Subframce Brace
Kind of a wired question but i got to know before i go ahead and purchase the bar.
If i have control arm's for a Type-R on my car right now will a ASR rear subframe brace fit for a normal Integra? Or do i have to get one that's meant for a Type-R?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icemangsr2 »</TD></TR><TR><TD CLASS="quote">you will need one for the DA chassis, which sadly they do not make. </TD></TR></TABLE>
OP's app. is DC
OP's app. is DC
pretty sure the OP has a 3rd gen Integra.
Not sure if ASR makes a brace for ITR's, since those came stock with a 22mm rear bar and stronger subframe anyway.
Just get the one meant for your car.
The real question is: which end links will work? I'm not sure if you can use stock GS-R end links with ITR LCA's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icemangsr2 »</TD></TR><TR><TD CLASS="quote">my bad. im on 4 websites posting and forgot which one i was on. thought i was in a gen2 specific forum. </TD></TR></TABLE>
if you have a gen2, ASR does not make a brace for your car. Only for 92+ civics and 94+ integra's. I have the ASR brace on my DC2 w/ ITR LCA's....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">pretty sure the OP has a 3rd gen Integra.
The real question is: which end links will work? I'm not sure if you can use stock GS-R end links with ITR LCA's.</TD></TR></TABLE>
endlinks are the same I have ITR lca and stock gsr sway and it all bolted up
gl
gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">
uhh... is that stock or stock-style GS-R sway bar brackets on that ASR brace? May I ask why? Why not mount the swaybar D-bushings and brackets directly to the ASR brace? That would be the strongest setup.
uhh... is that stock or stock-style GS-R sway bar brackets on that ASR brace? May I ask why? Why not mount the swaybar D-bushings and brackets directly to the ASR brace? That would be the strongest setup.</TD></TR></TABLE>
No, I'm using the Blox 21mm Rear Sway bar....which mount the sway bar bushings and brackets directly to the ASR Brace.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilvi3tkidxx »</TD></TR><TR><TD CLASS="quote">... my friend running 19 rear.. no asr... subframe is fine... but if u go 22.. ASR for sure... i shud sell mines.. im running 19</TD></TR></TABLE>
A 19mm will tear out of the subframe just like a 22mm will if not properly mounted.
https://honda-tech.com/zerothread?id=2404910
So the ASR doesn't mount to the LCA's or does it? Im just worried about the Endlinks if it will bolt up or not.
It looks like i should be alright since iH8RICERZ has the same setup.
Sorry forgot to say what car it was going onto
01-Integra
Here's a picture just for fun haha
01-Integra
he's right, thats my subframe
</TD></TR></TABLE>he's right, thats my subframe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20quang »</TD></TR><TR><TD CLASS="quote">
he's right, thats my subframe</TD></TR></TABLE>
my subframe looked the same prior to getting the ASR brace....
Here's what it looked like when I had the neuspeed rear sway bar set up
This might help answer some questions.
https://honda-tech.com/zerothread?id=2256572
One of the best upgrades I ever did.
I just installed my asr this past weekend along with 23mm jdm itr rear swaybar and skunk 2 lower control arms with BLOX endlink i must say the ride is so much stiffer and handles 100% better then ever it kinda makes me wanna take swirl drives everytime i turn the car on
GO FOR IT I spent about 400+ on everything and i must say it was worth every penny
navin
Oct 25, 2002 07:57 AM
