I need to know where these hoses go connected pics inside
Old Oct 13, 2008 | 09:36 AM
818blue818's Avatar
Default I need to know where these hoses go connected pics inside
i have a 90 integra ls 4dr i noiced some hoses wer not connected and 2 wer missing. would like to know where they go thanks.
Modified by 818blue818 at 3:32 PM 10/13/2008
Old Oct 13, 2008 | 10:10 AM
HONDRETTI's Avatar
Default Re: I need to know where these hoses go connected pics inside (818blue818)
that first pic says your speedo isnt working, you need to run your speedo cable into the big middle hole. the two other holes are for your power steering. there should be two tubes hanging around down there, which are probably plugged, unless you have no fluid hence no power steering.
Old Oct 13, 2008 | 10:12 AM
HONDRETTI's Avatar
Default Re: I need to know where these hoses go connected pics inside (HONDRETTI)
actually, i can see your speedo cable right there above your first circle to the left of those red/yel/green wires. stick it in the big hole.
Old Oct 13, 2008 | 01:26 PM
818blue818's Avatar
thanks heres a pic of the update. what about the other 2? from where to where do they go connected to? and what are they called incase i have to buy some?
heres a pic i just took. could it be those?
Modified by 818blue818 at 2:58 PM 10/13/2008
Modified by 818blue818 at 3:00 PM 10/13/2008
Old Oct 13, 2008 | 07:11 PM
HONDRETTI's Avatar
lol. you have 2 tubes and two holes. hmmm. stick the closest one to each hole. youre probably leaking all of you power steering if you have it. dont forget to put a clamp on each one
Old Oct 13, 2008 | 11:20 PM
818blue818's Avatar
those hoses are all the way in the bottom. looks like they wer cut. i saw some on autozone.com is it called power steering return hose? could i get help with the pic below also thanks
Modified by 818blue818 at 12:41 AM 10/14/2008
Old Oct 13, 2008 | 11:23 PM
818blue818's Avatar
i would also like to know where this cable is supposed to be connected, and what is it for? thanks
Old Oct 14, 2008 | 09:24 AM
vietnamezerice's Avatar
I know H22's have something similar to this (first pic)
Old Oct 14, 2008 | 10:01 AM
818blue818's Avatar
Default Re: I need to know where these hoses go connected pics inside (vietnamezerice)
thanks for ur input but how is that going to help me?
tahafisaka6
Oct 4, 2010 09:05 PM
jeff652
Nov 21, 2006 12:18 PM
RTW DC2R
Mar 18, 2005 11:38 PM
crexer
Apr 10, 2003 10:28 AM
takeheed
Sep 22, 2002 05:59 PM
