No Spark!!!!!!
Old Oct 13, 2008 | 09:15 AM
slowpro's Avatar
Default No Spark!!!!!!
I have a B16a2 that has been converted to OBD1 in my Ef after the rebuild we put it back in and now it will not get spark.
The Dizzy has power going to it. The igniter and coil have been changed.
Hell I put a OBD2 Dizzy on and used a jumper and still nothing.
What could this be I'm lost.
The starter has quit now also can this be related?
How can I check the ECU to see if it is working?
Old Oct 13, 2008 | 09:19 AM
ef-hatchcrap's Avatar
Default Re: No Spark!!!!!! (slowpro)
Switch the 2 white wires on your chassis side diizy plug thats the big round one. Just depin them and switch em.
Your statred probally took a **** because you were trying to start it so much
Old Oct 13, 2008 | 10:21 AM
SovXietday's Avatar
Default Re: No Spark!!!!!! (ef-hatchcrap)
If the starter is just sitting there "clicking" it's the battery being too low to start the car.
Check your grounds, namely the thermostat ground.
Old Oct 13, 2008 | 10:53 AM
slowpro's Avatar
Default Re: No Spark!!!!!! (SovXietday)
The car ran fine before the motor was yanked and rebuilt. I see no need to pull pins on the dizzy.
The started has been going for some time now. I was thinking they might be related thanks for the help on that.
I can't remember how many and were all the grounds go.
Old Oct 14, 2008 | 05:45 AM
slowpro's Avatar
Any help would be great
Old Oct 14, 2008 | 07:24 AM
JDM EF CR-X's Avatar
check ur CEL n if u get a code 0 its ur ecu ?
Hey_T
Nov 14, 2009 08:58 AM
ek4__
Oct 9, 2006 02:48 PM
ninety4lscoupe
Mar 21, 2006 02:47 PM
98gsrTEG
Aug 1, 2005 06:30 PM
b16std
Jul 21, 2005 05:25 AM
