where to buy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker »</TD></TR><TR><TD CLASS="quote">Hardtop Guy
Clicky</TD></TR></TABLE>
Great Choice. You can also pick up the hardware at any dealership, whether it be online (like hondaautomotiveparts.com) or local.
If i remember correctly the ap1 stikers are different. I believe the ap2 strikers were designed to fit both well.
I am using ap1 strikers with my hardtop right now but it rattles a little.
OP:
I highly reccommend that you to check out s2ki and other local forums first. You should be able to find them a lot cheaper. All that you really need are the side catchers.
do you have an ap1 or ap2?
OP:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K »</TD></TR><TR><TD CLASS="quote">If i remember correctly the ap1 stikers are different. I believe the ap2 strikers were designed to fit both well.
I am using ap1 strikers with my hardtop right now but it rattles a little. </TD></TR></TABLE>
Yeah, I have no idea which strikers are on my car but they don't seem to hold the top as tightly as I'd like. There was a brand new set in the trunk when I bought the car but they seem to be the same size... maybe I'll take one off and make sure though.
These are not my pictures...i got them from another board.
I believe left is the hardtop guy stikers (newer honda strikers) vs. the stock MY01 striker on the right...
Modified by ReddotsS2K at 9:47 AM 10/14/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 »</TD></TR><TR><TD CLASS="quote">Yeah, I have no idea which strikers are on my car but they don't seem to hold the top as tightly as I'd like. There was a brand new set in the trunk when I bought the car but they seem to be the same size... maybe I'll take one off and make sure though.</TD></TR></TABLE>
From what I understand the OEM AP1's should work fine with the hartops...
have you tried swapping them around? That should help hold the top on a little tighter if they are pretty wore out.
You already have you answers here... Are you talking about an OEM hardtop with seals and everything or do you have a mugen knock off and need window, seals catchers and everything else?
egtype-r
19
Mar 17, 2004 08:14 AM
