Seat options for 1990 Civic Ex?
I recently picked up a 90 Civic Ex as my college car.
Its got the pimp Red interior
In the future FUTURE I would like to swap it all out for black interior. I have seen in the past 94-01 Integra Seats in the Civic front and back!! I was wondering if anyone is familiar with this swap.
If you have, how high did you sit in them? Hopefully lower!
Thanks,
Shane
Modified by vtecn8ive at 11:42 PM 10/13/2008
Thanks,
Shane
i got a 91LX with driver side 98 gsr seats. all bolts in but the rear left bracket sticks out by an inch i uses a fat washer and a open end lug nut with a extended 12mm bolt. took out the gsr buckle and used the 91 sedan power seat belt and buckle had to drill the holes bigger inorder for the 17mm bolt to bolt back into the gsr seat. so yes im using 4 bolts if you want DA seats just use your ef brackets.
Woot 4000 post!
Anyways this is the car I first saw this swap going on in:
http://www.hondamarketplace.co...83776
I tried contacting the seller (i knew owner before this guy) but have yet to get an answer. hopefully he gets back to me.
I'm pretty sure thats for the Crx/Civic hatch and thats with the seat pan swap method. I was actually trying to avoid the seat pan method, as I've done similar before.
In the past i've installed Del Sol seats in Civic Hatch (ef) and I actually ended up welding and test fitting etc.
I just want something simple this time around.
use eney 91 civic seat i used a 91 si seat and did a pan swap the best part is the the passenger seat becomes the driver seat if u got a ef sedan
woot got a mint driver now and a passenger is simple to find after words
In the FAQ it looks like most of the guides show swapping out the seat pans, just transfer the foam and fabric onto your original seat pan. I think this will work for many different seats, however I remember hearing the integra's backrest is at a weird angle or something after matching it to the civic's seat pan?
Anyhow, I want to find the seats out of an 88-91 Prelude (Si?), I like their style and they feel nice to me! (pretty good side bolsters from what I remember).
I actually have a spare set of Prelude seats out of that year you are referring too. However, they were intended for a Civic years ago and have been sitting since. I'm debating trying to get them to work in the Sedan or not.
Jim Truett
Jul 14, 2007 09:16 AM
compwc18
11
May 2, 2003 02:19 PM
