B-Series TPS, are they all the same?
Old Jul 28, 2002 | 03:44 PM
mackymcg's Avatar
Default B-Series TPS, are they all the same?
I got a code for TPS Voltage too high, and from probing it it reads 5V all the time, plus my ecu reader show 96.6% throttle through the whole gas pedal range, probably a broken TPS.
I was wondering if all the B series engine TPS sensors are the same? How about the H and F sensors, are those the same?
Old Jul 28, 2002 | 05:34 PM
meept's Avatar
Default Re: B-Series TPS, are they all the same? (mackymcg)
Just as a data point, I am using a TPS from a '91 Integra LS on my B16A...no complaints and works just fine. I read somewhere that all the MPFI Honda TPS are the same...anyone else care to confirm or correct me?
Old Jul 29, 2002 | 06:49 AM
Daemione's Avatar
No personal experience (yet), but everything I've heard seems to say that most (if not all) Honda TPS's are interchangeable. The only issue lies in dremeling a slot in the screws so you can actually remove them from the TB. You're not technically supposed to be able to replace it - go to the dealer & they'll make you buy an entire throttle body assembly.
I think not.
Old Jul 29, 2002 | 06:54 AM
Mikey3000's Avatar
all obd1 tps's are the same. i don't know anything about obd2 or obd0.
Old Jul 29, 2002 | 09:24 AM
Katman's Avatar
they're all the same from 88 Si crx & Integra up to now.
Br1anPham
May 31, 2009 06:23 AM
Double Agent
Dec 27, 2008 09:43 PM
Team ICU
May 2, 2007 11:14 PM
TheSav
Apr 10, 2006 11:23 PM
evo
Apr 9, 2002 09:39 PM
