gsr cluster
Old Oct 12, 2008 | 08:12 AM
civicgsrb18's Avatar
Default gsr cluster
will a gsr gauge cluster fit in my eg?
Old Oct 12, 2008 | 09:55 AM
MurdersV8s's Avatar
Default Re: gsr cluster (civicgsrb18)
Not without alot of splicing or mounting modifications. Search around to see how much work it will take.
Old Oct 12, 2008 | 10:05 AM
unsungfate's Avatar
Default Re: gsr cluster (MurdersV8s)
not sure about your EG but i got a gsr cluster in my 99 si. takes a lot of splicing. and little modding
Old Oct 12, 2008 | 04:32 PM
bikewithnoname's Avatar
it takes alot of re pinning the cluster plugs.most are color related from the dc plug to the eg harness. then im not sure if the gsr cluster will fit in eg dash. i did the full dash conversion. its alot of wires. and your rear dfrost switch will blow your "back-up fuse" every time you hit the button. you have to wire it to a unused fuse slot. long story short. dont do what i did. if you want to it buy a dash harness from someone and do it. if your take yours out after all that work and it not work righrt is a bitch. if you dont do it right everything goes wonky my speedo became my tac and my tac became my speedo. after alls said and done the dc dash and dc cluster looks way better than the stock eg
JDMbiAtcH
Dec 1, 2005 08:35 PM
joenationwide
Jul 18, 2004 08:37 PM
Spence
14
Mar 25, 2004 04:50 PM
